I'm doing some video recording using a Canon Vixia HF R52 camcorder. When I pull the recordings off the camcorder, they are in 4 GB (maximum size) mp4 files, which I assume is because the SD card on which the camcorder records the video is formatted using FAT32.
For example, for a session that was about an hour long, the camera produced three 3.95 GB files of about 16 minutes of video plus one 2.7 GB file for the last 11 minutes.
I've combined the files into one larger mp4 file using MP4Joiner (http://www.mp4joiner.org). This gave me one 14.5 GB mp4 file with 59 minutes of video.
I uploaded that 14.5GB to Google Drive. Google chewed on it for a while and now that file can be viewed as a streaming video from Google Drive.
Because it took a long time to upload a 14.5 GB file, I did some looking and discovered that I could compress that file by running it through HandBrake. I use the "Fast1080p30" HandBrake preset. This results in a considerably smaller mp4 file to upload. I presume this has lost a little quality, but not that much, and these are, after all, home-made videos that don't need to be commercial quality.
I want to keep a backup on my computer in addition to the files saved to Google Drive. Should I keep:
- The original mp4 files downloaded from the camera
- The original large mp4 file created with MP4Joiner
- The compressed mp4 file created by HandBrake
Or is there something different I should be doing?
The earlier in the chain you backup, the less likely it is you backup some already degraded or broken file. (Of course keeping backups in one point is not the best idea because you will lose them when the HDD is stolen, burned in a fire/flood or simply breaks.) -
Keep the originals, and if you do any extensive editing/processing/composting or original/adaptive creative work, keep backups of your results (your “masters “), and if possible your workflow/session metadata (so you can quickly recreate and/or pick up where you left off).
All the rest is either temp/byproduct or lcd distribution copies all of which should be easy to reproduce.
Scott -
Always keep the originals.
And, if you want to combine into one file, look at the software that came with the camera. Most cameras include software designed to losslessly stitch together those 4 GB files. -
Agree. Better to let the tools do the job properly & quickly than having to do it manually and possibly experience glitches.
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 22:29 -
Video files deleted after watching a DVR once, and only audio files remain?
By jakieface in forum Video ConversionReplies: 1Last Post: 27th May 2017, 01:18 -
Only half the audio loads in Premiere Pro (some files) (Splitting files)
By The_Sociopath in forum EditingReplies: 1Last Post: 26th Jan 2017, 14:25 -
(Help Needed with ffmpeg) how do i batch merge audio files to video files
By wander799 in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2016, 14:40 -
Some Mp4 movie files are showing up as audio files on WD TV Live
By Sunshine Superman in forum DVD RippingReplies: 8Last Post: 21st Oct 2014, 13:59
