I asked the same question
elsewhere and one answer wasMy problem is that I only have a old not very powerful notebook (specs of the notebook Core I3, 8GB ram, display 1366 x 768, Win 7 x64) = I can't use some well known (but big) video editors - what I want to do is to combine some videos (that is simple) but I don't have a tool to adjust the volume of all parts (before I combine the parts) or normalize the result sound to the same level.
and my question here is = is there no converter with a integrated tool that is able to adjust the sound level?Have you tried OpenShot, Shortcut, or Natron? These are open source, cross platform, full feature video editors that use the FFmpeg library. Blender, an open-source, cross-platform, 3D creation suite, has a basic video editor built in as well. If these editors are too much or resource hogging for your need, you can also try demuxing the audios from the video files using a demultiplexer such as the tsMuxer or FFmpeg, adjusting the volume of the audio files with Audacity, which is an open-source, cross-platform audio editor, then muxing the audio files back into the video files, and finally combining the video files or containers into one file. Hope this helps
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
thanks allot for the quick answer. I will try both tools and let you know which experience I made.
Software that can precisely adjust audio length without changing pitch?
By bizzybody in forum AudioReplies: 5Last Post: 7th Oct 2017, 17:45 -
Adjust volume level (gain) of MP3s WITHOUT loss of quality possible?
By pxstein in forum AudioReplies: 3Last Post: 27th Mar 2016, 00:59 -
Drastic volume difference between two videos
By lonrot in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2014, 15:33 -
Adjust volume in a video without trans/re-encoding video stream?
By Brent212 in forum EditingReplies: 3Last Post: 1st Oct 2014, 07:03 -
Adjust volume of various files - ConvertXToDVD compressor didn't help.
By Beli in forum AudioReplies: 3Last Post: 9th Apr 2013, 00:00
