i explain. i have other brand of tuners avermedia and pinnacle. with avermedia happening issue that i have now with wintv hauppauge. using same antenna i cant get one specific channel. that happened before with avermedia and now with wintv [diferent channels each case]. i can remember that i uninstalled wintv 7 and tried install wintv 8 after that i lost that channel. i do all clean possible installations after this, without luck, also i have other two os in my pc win 7 and win 8. same thing. its pretty weird. yesterday i try with sage tv scanning channels with hauppage cards and i able to get that channel! but not with wintv , i prefer use wintv that sage tv.
with avermedia happening before with other channel in that case channel , not was available but plugging usb atsc avermedia in other pc that channel works.
i cant find way to fix it. channel don't appears in wintv not matter what. using same antenna cable with avermedia or pinnacle it appears also with wintv cards + sage tv too. but not with wintv
i update myself just for reference if somebody get same issue, those channels that i don't get before just change ota name and image resolution, after this im able to tuning those with hauppauge cards.
Internal ATSC tuner for Windows 10?
By bizzybody in forum Media Center PC / MediaCentersReplies: 7Last Post: 7th Jan 2017, 13:16 -
ATSC OTA TV Tuner for Vizio M50-DL
By kisianik in forum DVB / IPTVReplies: 14Last Post: 4th Dec 2016, 08:28 -
issue atsc channel aver volar max
By godai in forum ComputerReplies: 0Last Post: 19th Mar 2016, 01:13 -
question, witch old dvd / vcrs have an ATSC digital tuner
By tigergriz in forum DVD & Blu-ray RecordersReplies: 3Last Post: 15th Feb 2016, 15:39 -
Is onboard tuner image different than cable image of the same channel?
By brassplyer in forum DVB / IPTVReplies: 9Last Post: 13th Jun 2013, 13:27
