I am adding .mp4 movie clips to dvdfab in creator mode, so far I have added just 2 clips 1 is 333Mb other is 399MB but soon as I added it in the menu of dvdfab it says 3716/4300mb then I added 2nd and now it says 4786/4300 but 333mb + 399MB only totals 732MB so I am a bit lost on this why do it say 3716 after adding just a 333MB .mp4 clip then 4786MB after adding another 399MB .mp4 clip am I going over the 4300MB limit them for just 2 mp4 clips 333MB and 399MB
I've never used creator mode but it sounds as if you're trying to create a standard DVD. The source format is not DVD complaint so has to converted, hence the size change
Standard DVD typically holds up to 2 hours. Can be a little more, but it forces the bit rate lower, PQ Probably will get wors -
.mp4 can be made into a DVD and that is what DVDFab is doing. MP4 files are not DVD - which is a forum of MPEG2 files. Therefore the software is making them into DVD files before continuing. MP4 files can be put on a DVD as data and not be converted, but then most DVD players cannot play the resulting data disk.
You must be confusing the term of DVD - the disk - with the DVD the standard for making a compliant media format, which is made with MPEG2 files not MP4 files.
To DVDFab or not to DVDFab
By Yanta in forum Blu-ray RippingReplies: 32Last Post: 8th Jul 2023, 17:31 -
dvdfab help
By natty in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2018, 04:49 -
AnyDVD HD to DVDFab
By maxrockpro in forum Blu-ray RippingReplies: 4Last Post: 30th Jul 2014, 08:12 -
DVDFab screwed!!!
By deadrats in forum Latest Video NewsReplies: 1Last Post: 11th Mar 2014, 10:07 -
DVDFab
By agtjones in forum AudioReplies: 6Last Post: 27th Feb 2014, 16:53
