Results 1 to 28 of 28
  1. Looking for a user friendly tool that can extract subtitles from a .ts file.
    I tried CCExtractor, TSDocter, SubTitleEdit but probably, or better... I am sure, I must be doing something wrong.
    Am not an expert at all.
    After hours of trying I gave up and ask here. No doubt folks here are experienced and know what to do/give me suggestions.
    First the .ts file: please find details below.
    I have added some screenshots of CCExtractor. As for the PDF file, click on the first screenshot, to display the other screenshots.
    Maybe someone can tell me what I should tag.
    Hope someone can help me.
    Or maybe I should use some other tool?
    Thanks.
    General
    Complete name                            : bla bla_20180123_2245.ts
    Format                                   : BDAV
    Format/Info                              : Blu-ray Video
    File size                                : 9.34 GiB
    Duration                                 : 2 h 12 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 10.1 Mb/s
    FileExtension_Invalid                    : m2ts mts ssif
    Video
    Menu ID                                  : 33020 (0x80FC)
    Format profile                           : High@L4
    Format settings, ReFrames                : 4 frames
    Format settings, GOP                     : M=3, N=15
    Codec ID                                 : 27
    Bit rate                                 : 8 680 kb/s
    Maximum bit rate                         : 8 582 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 25.000 FPS
    Standard                                 : Component
    Scan type                                : MBAFF
    Scan type, store method                  : Interleaved fields
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.167
    Stream size                              : 8.06 GiB (86%)
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Text #1
    Format                                   : DVB Subtitle
    Codec ID                                 : 6
    Delay relative to video                  : 3 s 196 ms
    Language                                 : Dutch
    Text #2
    Codec ID                                 : 6
    Language                                 : 888
    Text #3
    ID                                       : 3329 (0xD01)-888
    Format                                   : Teletext Subtitle
    Language                                 : Dutch
    Language, more info                      : For hearing impaired people
    Other
    ID                                       : 3329 (0xD01)-100
    Format                                   : Teletext
    Language                                 : Dutch
    Image Attached Thumbnails CCExtractorScreenshots.pdf
Name:	SnagIt-21032018 114145.png
Name:	SnagIt-21032018 083335.png
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    In the last picture it looks like you were getting text. Was the text it was outputting wrong or something?
    Sep 2013
    Europe
    Open your .ts file with SubtitleEdit. It will automatically detect your sub, then you can OCR and save as .srt or convert as .sup etc.
    Other method is to use ProjectX to extract them as .sub. It's a bit pain in the ass to configure but can do the job. Prefer SubtitleEdit first.
  4. Originally Posted by KarMa View Post
    Thanks.
    I did not check that, but it was -not- the text belonging to the documentary. I assume it belonged to either the commercials, etc. at the beginning or the stuff at the end. CCextractor only created 1 .srt.
    Now, to get rid of confusion on that, I -just- removed the commercial at the beginning and the crap at the end (roughly 5-7 minutes) and am now re-encoding it to a .mkv file (TMPGEnc Video Mastering Works 6).
    It'll take some time.
    Maybe it will be easier then, meaning: just the actual documentary and a .mkv file.
    Any suggestions how to easily extract the subtitles (also with CCExtractor?)
  5. Originally Posted by HelpVid View Post
    Tried that as well (Video->open).
    It took a while and then it crashed
    An application error occurred in Subtitle Edit 3.5.6.0.
    Please report at
    httxx://github.com/SubtitleEdit/subtitleedit/issues with the
    following information:
    Error Message: Index was outside the bounds of the array.
    Stack Trace:
    at Nikse.SubtitleEdit.Core.BluRaySup.BluRaySupParser. BigEndian
    Inti6(Bvte[l buffer, Int32 index)
    etc.etc.
    Happened twice, so I gave up on that. Maybe the file was too large, a little over 10GB.
    As written earlier, I am now re-encoding it and see what happens (or better: what comes out)
    Sep 2013
    Europe
    Yeah, large file can be a problem. You still try ProjectX. You'll have to select the ID of the sub (0xCFF or 0x80FC) and deactivate all other stream (not needed for sub extract). In preferences select export sub. Then it would be good. Maybe try a different color (still in preference).
  7. Let's see what comes out, right now the encoding is at 60% now, the .mkv file is about 8.7GB.
    Sep 2013
    Europe
    I assume you'll loose any sub track after encode, right?
    canada
    You don't need to re-encode a ts to mkv,thats just a container format,just load the ts into mkvmerge and output as mkv.
    Sep 2013
    Europe
    Mkvmerge doesn't support dvbsubtitle (at least the time I work on this it wasn't the case).
  11. I'm a Super Moderator johns0's Avatar
    canada
    Have you tried the latest mkvmerge?From what i read last year DVB Subtitle support was being added.
    Sep 2013
    Europe
    Didn't know. Good to know.
    Sep 2016
    Poland
    I use both of the above applications.
    CCE serves to extract subtitles that appear in teletext from the stream. Remember to enter teletext page number with subtitles (Decoders / Teletext decoder / Page for subtitles), because sometimes the program does not draw anything. Sometimes, I have to pass a .ts file through VideoRedo, because CCE throws a communique with "too big a file".
    I also use Subtitle Edit (only for dvb subtitles). You have to remember to install Tesseract. Subtitles extracted using this method always contain errors. You need to configure the tools contained in the SE for yourself.
  14. Thanks for all the replies folks! Really appreciated.
    Now, I have the recordings in both formats:
    a. the original .ts file (with commercials at the beginning and the end) - size 10GB
    b. an encoded to .mkv file (commercials removed)
    Subtitle Edit: opening the .ts file - crashes - twice - it takes verrry long to open the file, it hangs at 99% and then crashes - file probably too big
    CCExtractor: using the .ts file - the only thing I managed is to get subtitles of a part that I don't need, but not the part I need
    that is the status so far.
    Remember: I am not an expert, far from that...
    I downloaded and installed MKVToolNix 21.0 - at the end of the setup it says:
    If you need a GUI for mkvextract then give these projects a try:
    gMKVExtractGUI
    MKVdeaver
    I tried
    Subtitle Edit with the .mkv file - no subtitles found
    CCExtractor - tried various options, but frankly, I don't know exactly what option to use.. Anyway, nothing came out
    mkvtoolnix: I have now launched mkvtoolnix and loaded the original .ts file
    Got the below screen, but eh ... now what?
    The 2nd screenshot shows when I load the .mkv file.
    thanks.
Name:	SnagIt-22032018 082613.png
Name:	SnagIt-22032018 083451.png
    Sep 2016
    Poland
    Try to upload the .ts file to MKVToolnix, select only the tracks with subtitles and export them. Then put this extracted file into Subtitle Edit.
    Have you checked if you have Tesseract-OCR in the Subtitle Edit folder?
    Extracting subtitles using Subtitle Edit from a .ts file.
  16. I selected the subtitle track only, but what do I have to click on next...??
    I believe tesseract is available.
    Thanks for helping me out....
Name:	SnagIt-22032018 085906.png
Name:	SnagIt-22032018 114606.png
    Sep 2016
    Poland
    Yes, "start multiplexing".
    I have something like this:
    https://forum.videohelp.com/images/imgfiles/TvPpneh.png
  18. Thanks.
    I installed teseract latest version and copied it to Subtitle Edit (delete existing one)
    Import video, but no subtitles
    MKVTool - did multiplex - file created xyz.mks
    Within Subtitle Edit import mks file - nothing
    MKVToolNix export to .txt file - nothing
    Well, I have spent many hours on this. Apparently it is too complicated for all the tools I used.
    CCextractor, TSDoctor, ProjectX (don't know how that works) I let it rest, it seems to be very complicated.
    Thanks anyway.
  19. You could try to convert DVB subtitles to DVD subtitle format with ffmpeg - Teletext and DVB subtitles are two different things.
  20. I think there is something peculiar with these subtitles.
    I also tried idealshare using the original .ts file.
    https://www.idealshare.net/video-converter/extract-subtitles-from-mkv-vob-avi-mp4.html
    in my case subtitles are listed, but there are no [Save as] buttons.
    when I use the .mkv file (removed commercials), there is no subtitle track, only audio/video, so
    my guess is they are burned in.
Name:	SnagIt-23032018 131504.png
    Sep 2016
    Poland
    All these unsuccessful attempts apply to the same .ts file?
    Try to record other files from different TV channels.
    If you can, put in a small sample of the file for hosting. I will see if something can be learned from it.
  22. Member
    Sep 2013
    Europe
    I was thinking the same. Please don't hesitate to share a small sample (made using mkvmerge or tsdoctor).
  23. Member
    Sep 2016
    Poland
    Check PM.
  24. Member
    Sep 2013
    Europe
    The one with Subtitle Edit in the title do have sub in it:
    [Attachment 45015 - Click to enlarge]
    [Attachment 45016 - Click to enlarge]
    Could you make a sample of your "bla bla_20180123_2245.ts" video as well?
  25. Member
    Sep 2016
    Poland
    You got two files. One with DVB subtitles - you opened it.
    The second contains subtitles in the teletext - you must open it in CCExtractor.
    https://forum.videohelp.com/images/imgfiles/qU0xnJK.png
    Enter the page number of the teletext with subtitles - in this case it is 777, because on this page in Poland subtitles are broadcast.
    https://forum.videohelp.com/images/imgfiles/gGrMNaq.png
    https://forum.videohelp.com/images/imgfiles/9nM5OPb.png
    I thought maybe you do not know exactly what to do?
    Once you have achieved what you showed on the screens, press "Lancer OCR".
    The OK button (on the right) is only pressed after "reading" the last line.
    Set everything up like on the screenshot.
    https://forum.videohelp.com/images/imgfiles/JolHO2L.png
  26. Many many thanks for the help so far. The teletext thing indeed was the solution. In my case I had to take 889.
    Initially I tried 888 (which 'officially' is teletext here, but in the CCExtractor results it showed 'Notice: Teletext page with possible subtitles detected: 889'
    So I tried that one and got the results now. Super!
    Again many many thanks.
    It is very 'precise' - I mean - one needs to know to select teletext and even the exact page, else, nothing.
    There is no room for mistakes. No results for dummies like me..
    Of course I have made screenshots of all the steps for 'future cases', should I need it again.
    Truly appreciated your help!
  27. Member
    Sep 2016
    Poland
  28. Member
    Mar 2019
    United
    Easiest method I've found is just upload the .ts file to YouTube. Make sure it's on a channel you don't care about copyright strikes and upload it to "private" setting. YouTube will automatically parse out the subtitle file and you can then download it.
