I installed QTGMC by following the instructions on this page. I installed:
I opened the following avs script in VirtualDub:AviSynth 2.6
QTGMC v3.357
FFTW3 library
MaskTools2
MVTools2
nnedi3
RgTools
SMDegrain
AddGrainC
dfttest
EEDI2
EEDI3
FFT3DFilter
KNLMeansCL
PlanarTools
TDeint
yadifmod2
AnimeIVTC
Microsoft Visual C++ 2015 Redistributable Update 3 (32-bit)
Microsoft Visual C++ 2015 Redistributable Update 3 (64-bit)
After opening this avs script on a PC with Windows 10 64-bit, there are no errors.Code:LoadPlugin("drive:\path\to\DGDecode.dll") MPEG2Source("dgindex project.d2v") AssumeTFF QTGMC(Preset="Super Fast")
After opening this avs script on a PC with Windows 7 64-bit, the following two errors are displayed:
The program can't start because VCOMP120.DLL is missing from your computer. Try reinstalling the program to fix this problem.The procedure entry point clEnqueueFillBuffer could not be located in the dynamic link library OpenCL.dll.
VCOMP120.DLL is vc redist 2013. Try installing Microsoft Visual C++ 2013 Redistributable.
I installed Microsoft Visual C++ 2013 Redistributable, 32-bit and 64-bit.
Now the error "The program can't start because VCOMP120.DLL is missing from your computer. Try reinstalling the program to fix this problem." doesn't display.
But the error "The procedure entry point clEnqueueFillBuffer could not be located in the dynamic link library OpenCL.dll." continues to display. -
Then you may have an older graphic chipset which does not yet support OpenCL in the version required by KNLMeansCL. You may have to use a preset for QTGMC which does not rely on this plugin.
I solved the problem in the following way:
- in "C:\Windows\System32" I renamed the file "OpenCL.dll" to "OpenCL.dll.bak";
- in "C:\Windows\SysWOW64" I renamed the file "OpenCL.dll" to "OpenCL.dll.bak";
- I copied "OpenCL.dll.bak" from "C:\Windows\System32" to "C:\Users\username\Desktop";
- I renamed "OpenCL.dll.bak" from "C:\Users\username\Desktop", to "OpenCL.dll";
- I copied "OpenCL.dll" from "C:\Users\username\Desktop" to "C:\Windows\SysWOW64".
And after I did the steps above, the error "The procedure entry point clEnqueueFillBuffer could not be located in the dynamic link library OpenCL.dll." is not displayed after I open the avs script in VirtualDub. -
Very strange. Usually there is a reason why a 64-bit DLL is located in "C:\Windows\System32", and a 32-bit DLL is located in "C:\Windows\SysWOW64" which is cloaked as "C:\Windows\System32" for 32-bit applications by Windows. You should never try to mix both types up. A correct installer of your graphic driver should have put the correct variant in the matching directory.
I tested QTGMC v3.357 and the avs script above, on 3 PCs.
PC 1 has a Radeon HD 5450 GPU. PC 2 has a Quadro NVS 160M. PC 3 has Celeron 1007U and doesn't have a dedicated GPU.
Only on PC 2 the error "The procedure entry point clEnqueueFillBuffer could not be located in the dynamic link library OpenCL.dll." was displayed.
For PC 2, I found two ways to prevent the error above:
1. By moving "OpenCL.dll" from "C:\Windows\System32" to "C:\Windows\SysWOW64".
2. Or by replacing "OpenCL.dll" in "C:\Windows\SysWOW64", with "OpenCL.dll" from dllme.com.
I don't know if these two solutions are proper solutions... but they work...Last edited by codemaster; 21st Mar 2018 at 17:38.
is this MSVCR120.dll for windows 32 or 64bit?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2016, 11:04 -
MSVCP60.dll MSVCRT.dll MFC42.dll: wich of this dll's do video deinterlace?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2016, 12:40 -
LG Blu-Ray writer WH16NS40 write errors Windows 8
By mail2tom in forum DVD & Blu-ray WritersReplies: 5Last Post: 20th Mar 2015, 06:55 -
TMPGlib.dll TMPGlibP3.dll TMPGlibP4.dll
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2014, 12:02 -
Video errors after updating to Windows 8.1
By Martin_DK in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2013, 11:20
