Magewell has added support for HDR. I'm a little confused on how to get HDR signal and go about recording it.
Capture Card: Magewell 4K Plus
Link: http://www.magewell.com/pro-capture-hdmi-4k-plus
Article Announcing HDR Support: http://www.magewell.com/6377.html
1. The part I'm getting a little confused on is the EDID file and how to generate or obtain one. I want to use my PS4 Pro to capture HDR footage.
2. Once I obtain a EDID file how do I import such file into the 4K Plus Capture?
3. Finally what 3rd party software can capture HDR? Would software like amarectv or VirtualDub (or VirtaulDub 2 ongoing Open Source development) work?
- Thanks
Link: http://www.amarectv.com/english/amarectv_e.htm
Link: http://www.virtualdub.org/
Link: https://sourceforge.net/projects/vdfiltermod/
It appears that currently, Magewell is not making the HDR enhancement available to anyone but software developers.
From the article that you linked to:
The article that you linked to also indicates that there is currently no software available to use this new feature.The HDR enhancements for 4K, HDMI-connected Pro Capture Plus cards are available immediately to developers, with end-user software to follow.
Be patient. The announcement was made only 6 days ago.HDR capture and recording will also require HDR-enhanced software applications. In addition to anticipated support from third-party vendors, Magewell will provide a sample application for testing and development, and plans to add HDR recording capabilities to a future version of its own Capture Express software. Captured files can then be played back on HDR10-compliant devices through compatible playout hardware or software.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
After talking to two people both working with HDR one being Magewell support staff. Magewell said HDR can be done now with any EDID that has HDR enabled and imported to the capture card without the need of the SDK. Magewell uses Mi TV, Other devices like HDFury and such will work too.
This is a direct quote from Magewell:
"If you have the ability or the experience on how to preview the HDR signal,you do not need to wait for our SDK."
I also came across this comment on a gaming site about HDR 4K capturing:
" we had to make sure lossless capture would finally be possible with Amarec. We installed a faster SSD and it did the trick" -
I don't know how to do it, but I guess Magewell is suggesting that you obtain an EDID INF file from one of the other devices which accept HDR video.
It looks to me like there is information in the Magewell Pro Capture user manual about using the driver properties dialog window to replace the EDID with a new one. You should probably save the existing EDID before experimenting.
I have no idea how to configure AmarecTV to capture HDR metadata. Maybe you should ask the guys who posted about 4k HDR capture on the other forum.Ignore list: hello_hello, tried, TechLord, Snoopy329
Processing HDMI input with EDID emulation
By taylorswift1111 in forum Capturing and VCRReplies: 4Last Post: 17th Aug 2017, 19:08 -
Adobe Premiere Pro CS5.5 Import Export Settings for Sony HDR CX240
By Andalite in forum EditingReplies: 7Last Post: 1st Aug 2014, 05:52 -
1080p (60p) Recording from Sony HDR-CX290 looks grainy
By jtdude100 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Jan 2014, 18:06 -
How to Capture (Import) HD video from SOny HDR-HC7 (Cassette MiniDV) to PC
By YuYuKu in forum Capturing and VCRReplies: 2Last Post: 30th Sep 2013, 22:18 -
Sony Handycam HDR-SR12E re-recording to external Blu-ray burner
By Play Me in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2013, 18:42
