I've tried both the change FPS and Resample FPS filters (also changed the Video Output from Copy) and it's still the same length. I want the video to be slower so that the length increases by a few seconds.
Can Avidemux handle this or should I look to something else?
I don't use AviDemux and I'm sure someone that does will come along to answer your question.
But it's a simple matter to slow a video by changing the framerate using AviSynth. For example, if the video is 23.976fps, by adding the line:
AssumeFPS(20)
to the script, the video is slowed to 20fps. And depending on the type of video, you can do it in other ways without even reencoding the video (AviSynth requires reencoding). -
Avisynth is not an application you open. It runs in the background as a frameserver and it's actions are controlled
by a script which can be opened by any app that accepts these scripts, such as ripbot264, virtualdub filtermod and many more
I tried avidemux and it slows down the video just fine. I loaded a short PAL clip (25 fps) and set "copy" to mpeg4 AVC,
set video/configure to general tab/basic/very fast, and added the filter Change FPS and set destination frame rate to 23.96
For audio I chose aac, and under filter I chose frame rate change Pal To Film
Successfully created an NTSC frame rate (film) conversion
Slowing down video playback speeds just a little....
By Arcadiune in forum Video Streaming DownloadingReplies: 4Last Post: 18th Nov 2017, 13:02 -
I need help rotating a video with AVIDEMUX 2.6
By cinema in forum EditingReplies: 3Last Post: 14th Aug 2015, 04:01 -
problems slowing down video
By asiletto in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2015, 14:18 -
Slowing down a video gradually. Or speeding it up. But gradually.
By john1967 in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2015, 22:47 -
.TS video slowing down in a preview window, but fine on the timeline
By Mayx in forum Newbie / General discussionsReplies: 5Last Post: 1st Aug 2014, 00:50
