Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    Apr 2014
    malaysia
    ffmpeg not work on two command vignete and blur in one line , why ?
  2. What does your command line look like? It's typically a problem with the syntax then such things don't work.
    users currently on my ignore list: deadrats, Stears555
    Apr 2014
    malaysia
    ffmpeg -y -i "input.avi" -filter_complex "[0:v]crop=in_w/1.5:in_h/1.5in_w-out_w)/1.5+((in_w-out_w)/1.5)*sin(t*0.5)in_h-out_h)/1.5 +((in_h-out_h)/1.5)*sin(t*0.2),boxblur=1:1,vignette=4,scale=1280:720,setdar=16/9; [0:a]volume=6" -vcodec libx264 -pix_fmt yuv420p -r 30 -g 60 -b:v 1400k -profile:v main -level 3.1 -acodec libmp3lame -b:a 128k -ar 44100 -preset superfast "output.mp4"
  4. Thrwoing out some of the filter complex stuff and using:
    -vf boxblur=1:1,vignette=4,scale=1280:720,setdar=16/9
    seems to work.
    Using the command line you posted throws:
    [AVFilterGraph @ 000002d9c328ffc0] No such filter: ')'
    removing the '),' before boxblur throws:
    Cannot find a matching stream for unlabeled input pad 0 on filter Parsed_boxblur_1
    to sleepy to look into it, but the '),' before boxblur seem wrong.
    Apr 2014
    malaysia
    i try but it still error ....... what happen actually ?
    ffmpeg -y -i "input.avi" -filter_complex "[0:v]crop=in_w/1.5:in_h/1.5 : (in_w-out_w) / 1.5+ ((in_w-out_w)/1.5) * sin(t*0.5) : (in_h-out_h)/1.5+((in_h-out_h)/1.5) * sin(t*0.2) ,boxblur=1:1,vignette=4,scale=1280:720,setdar=16/9; [0:a]volume=6" -vcodec libx264 -pix_fmt yuv420p -r 30 -g 60 -b:v 1400k -profile:v main -level 3.1 -acodec libmp3lame -b:a 128k -ar 44100 -preset superfast "output.mp4"
  6. This works. Save as a batch file:
    ffmpeg -y -i "input.mp4" ^
     -filter_complex "[0:v]crop=in_w/1.5:in_h/1.5:(in_w-out_w)/1.5+((in_w-out_w)/1.5)*sin(t*0.5):(in_h-out_h)/1.5+((in_h-out_h)/1.5)*sin(t*0.2),boxblur=1:1,vignette=4,scale=1280:720,setdar=16/9[out]" ^
    -map "[out]" ^
    -vcodec libx264 ^
    -pix_fmt yuv420p ^
    -r 30 ^
    -g 60 ^
    -b:v 1400k ^
    -profile:v main ^
    -level 3.1 ^
    -acodec libmp3lame ^
    -b:a 128k ^
    -ar 44100 ^
    -preset superfast ^
    "output.mp4"
    I didn't test the audio.
    By the way, don't say "some error" - please copy the error message exactly.
    Apr 2014
    malaysia
    now it work
    thank you,man
    thread FINE
    Dec 2005
    Canada
    @raffriff42
    Than you for the bat file.
    I didn't know that each of the commands could have their own line.
    Makes it much clearer for the likes of myself.
