Hello,
I am new to this forum so forgive me if I have posted in the wrong thread.
I've burnt an .mkv file to DVD using Toast but there is no audio in the playback.
In the past, in order to burn to DVD, I've converted .mkv files to .mov and it works (usually) without a problem but this time the conversion left the audio/video completely out of sync!
Would be grateful for any advice.
Thank you in advance.
Closed Thread
A bit more information may help
MKV files can contain many different audio formats so it depends a lot on the media player you are using if it supports the particular audio format of the audio in the MKV file.
Post a MediaInfo report on the MKV file this will reveal the contents of the MKV file, video, audio and subtitles, chapters etc
Are you Authoring the file to produce a normal DVD to play in a standalone player ie with VIDEO_TS and AUDIO_TS folders? Or are you simply burning the MKV file to a DVD blank as data?SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Thanks for responding so promptly netmask56 but I'm some distance from the techies on this site so please bear with me.
How do I extract the Mediainfo report?
I'm simply burning the the .mkv file to a blank DVD.
Run MediaInfo and select the MKV file for it to inspect - then set the View in MediaInfo to TEXT. Then you can simply copy and paste the report into a post. It would look like this
Complete name
Format : Matroska
Format version : Version 2
File size : 1.44 GiB
Duration : 53 min 43 s
Overall bit rate : 3 835 kb/s
Encoded date : UTC 2011-07-15 21:33:00
Writing application : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 8 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 3 375 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.153
Stream size : 1.27 GiB (88%)
Writing library : x264 core 115 r2008 4c552d8
Encoding settings : cabac=1 / ref=8 / deblock=1:2:2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 148 MiB (10%)
Service kind : Complete Main
Default : Yes
Forced : No
Thank you netmask56. As suggested:
General
Unique ID : 195371661343720324487601581319091767268 (0x92FB3699F449418796CC51ABD5B5C7E4)
Complete name : /Users/erik/Downloads/Phantom.Thread.2017.DVDSCR.x264-DrinkBetterWater.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.08 GiB
Duration : 2 h 10 min
Overall bit rate : 1 188 kb/s
Encoded date : UTC 2018-02-07 11:38:22
Writing application : mkvmerge v6.7.0 ('Back to the Ground') 64bit built on Jan 8 2014 15:10:52
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 8 frames
Bit rate : 940 kb/s
Width : 720 pixels
Height : 464 pixels
Display aspect ratio : 1.85:1
Original display aspect ratio : 1.85:1
Frame rate mode : Variable
Color space : YUV
Bit depth : 8 bits
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AC-3
Codec ID : A_AC3
Bit rate : 224 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 208 MiB (19%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:12:27.079 : en:Chapter 2
00:23:59.104 : en:Chapter 3
00:34:29.350 : en:Chapter 4
00:45:07.037 : en:Chapter 5
00:57:22.021 : en:Chapter 6
01:10:57.953 : en:Chapter 7
01:21:31.202 : en:Chapter 8
01:34:52.303 : en:Chapter 9
01:47:15.378 : en:Chapter 10
02:00:46.973 : en:Chapter 11
02:09:59.158 : en:Chapter 12
Burning MKV to DVD so it will play on DVD Player?
By darkdream787 in forum Authoring (DVD)Replies: 9Last Post: 10th Apr 2017, 23:54 -
Burning avi's, mp4's and mkv's to DVD/Blu-Ray using ImgBurn
By Ronnie_ASA in forum Authoring (DVD)Replies: 9Last Post: 22nd May 2016, 08:58 -
Burning MKV to DVD with Toast 12 questions....
By Reesche in forum MacReplies: 25Last Post: 22nd Dec 2014, 22:28 -
Lossless burning MKV H.264 10bit video to DVD????
By uranometria in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2014, 08:11 -
MKV to AVI Audio Out of Sync (DVD Burning)
By StardustZero in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2013, 21:28
