Hi, i'm looking for a way to convert video files with FLAC sound, to the same quality of video, but with WAV or MP3 Sound.
I've been trying to do this with Xmedia Recode, where i can just copy the video output, and change the audio output. But i can't seem to get the subtitles working. The subtitles are encoded in the original video, but when i convert the video the subs are gone.
Does anyone know an easy way to convert the audio of videos, while keeping the subtitles like in the original video?
This will give you original video and subtitles with WAVE audio. Of course, use the file extensions appropriate to your format.Code:
ffmpeg -i myinput.avi -c:v copy -c:a pcm_s16le -map 0 myoutput.avi
Can you make a screenshot of the Xmedia "subtitle" tab? It should be possible to copy them in most cases. Make sure you get them into the "output" field on the right and select "copy" (or "render" if your player doesn't support soft subtitles).
What container format are you choosing (mkv, avi, mp4)? Not all containers support all subtitles. -
It's a mkv video, so i just copy the video, while changing the audio from FLAC to WAV. My TV doesn't support FLAC sound, so i'm looking for a way to play these video's on my tv without having to download them in another format. It's just strange that xmedia doesn't add the subs, even though i copy them to output.
According to your screen dump you don't copy the subtitless but Render them.even though i copy them to output.
What I miss in your screen dump is the codec (ASS) to be used for rendering.
[Attachment 44933 - Click to enlarge] -
re-combine the old mkv with the new audio into a new mkv. use mkvtoolnix gui to open the old one, un-check the flac audio, add the new video with the converted audio and un-check everything but the new audio. multiplex the streams into an new mkv.
MeGUI Converting to FLAC
By VideoFanatic in forum AudioReplies: 5Last Post: 21st Jan 2018, 13:56 -
Is FLAC file actually DTS-HD MA?
By PhilJW in forum AudioReplies: 7Last Post: 9th Dec 2016, 23:59 -
Cue+Flac file splitting
By efiste2 in forum AudioReplies: 5Last Post: 30th Jul 2015, 18:55 -
flac file to Mp3
By blinky88 in forum Newbie / General discussionsReplies: 23Last Post: 14th Jul 2014, 22:19 -
Converting FLAC to which format ?
By txl in forum AudioReplies: 34Last Post: 31st May 2013, 03:36
, care to explain?
