hey,
is there a way to auto-stretch an event's length when changing the playback rate back to 1 through the event's properties? like how vegas reduces the event's length when ctrl+dragging, when adjusting the playback rate?
i changed the playback rate of an event by holding down ctrl and dragging, and the event was modified in length.
now i want to change the playback rate back of the event back to 1, and have the event's length go back to the length is needs to be for the playback rate of 1. basically the opposite of the auto-stretch vegas down when using ctrl + drag.
is this a thing vegas can do?
how can i go about reconnecting the event to it's adjacent events, changing it's playback rate to 1, so that the video looks like it plays seamingly again?
thanks
Results 1 to 12 of 12
Right-click, Properties, Playback Rate, set it to 1. Then you will have to drag the event back to the length you want.
i know,
what i'm asking for is a way to set the length of the event automatically when the playback speed is set to 1
if i drag the length manually, there's a chance the video will not be correctly timed with the next event... -
If you mean you want it to be the same length it was before you stretched it, the only thing I know of is Ctrl-Z. Unless you used the whole length of the event, in which case you can drag until you see the end marker.
ctrl-z's not an option as i've done the changes many saves ago, and the event is part of a 1 hour vid, which is the only vid in the timeline.
is there a way to ask an event to stretch until the point in the video the next event starts? -
Do you mean you need auto ripple on? That adjusts following connections.
If you need to find out correct lenght just put the same clip into timeline and match it or match it to the same frame. -
from what i've used auto-ripple. it just brings the next events into the left, when you delete an event. can it match the video, when pushed to the left, of the previous event?
this whole system is a mess when wanting to do what i'm trying to do. such greatness, vegas, then a simple task like this hinders me for days.
so i guess i'll have to manually get times, and stitch stuff together with time. -
Well, it could kind of turn into a disaster if having auto ripple on, imagine someone does the same thing as you, changes speed back to 1, and Vegas shifts things to the left (in your case). Also it could shift things to the right (if you sped up). The outcome is not clear. So it just stays as it is. Vegas has that V shaped gap on the clip, so you know if that clip was extended beyond length one or not.
Anyway, it seams like couple of second problem. You have a frame on the right and then find the same one on the left, then cut it. Use mouse wheel to zoom in or out all the way. It anchors slider on the timeline just like a + or manual. -
yes, to bad for me that the point in the video i'm editing is in the middle of the video, so i can't use the v shape thing either.
lemme show you exactly what's going on, it's been a pain to explain..
i'll try and stitch things together, but for anyone else that might have a better solution also.
what you'll see me doing is reducing the event length of a portion of the video when using ctrl+drag to speed it up, and then wanting to set the event's speed back to normal, but i don't know what the event's length is/should be, so that the end of the event plays seamingly with the next event.
https://www.youtube.com/watch?v=kgl-yUujwrs&feature=youtu.be
i also cannot just delete the event i changed and the next event, and stretch the left event to the end, cause there are multiple events after these that have been edited.Last edited by ricmetal; 15th Mar 2018 at 17:33.
This is exactly what I or perhaps others thought it was. There is nothing to it.
Frankly, I do not understand what the problem is. It is just simple frame matching. Either you find a frame from the left or from the right, or deleting that clip and extending from whatever direction to matching frame or the other way around. Or just drop that whole video to another track temporarily and use it as a reference for cutting , whatever way. Easy to solve it.
Vegas Pro 11&12 - Event on Timeline question
By GT Music in forum EditingReplies: 3Last Post: 11th Oct 2015, 13:59 -
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 05:19 -
Live Event Capture and Immediate Playback
By MidwestMonsters in forum Capturing and VCRReplies: 4Last Post: 4th Oct 2013, 17:03 -
Sony vegas 11 frame-rate
By cojothebro in forum EditingReplies: 11Last Post: 7th Sep 2013, 11:02 -
cant open sony vegas pro 11 'event pan/crop'
By kitsuneee in forum EditingReplies: 7Last Post: 4th Apr 2013, 22:11
