How do you remove encryption on a .mp4 movie I have been told there is passkey but dont understand it all.
Closed Thread
Results 1 to 12 of 12
sounds more like you've got a virus waiting to happen. if an mp4 says you have to do something odd to open it, that something will most likely infect your computer. encryption has to be removed before converting to mp4.
No maybe I have not explained things. I have bought a program called CinDe HD to remove cinavia but it don't work on this 1 movie. It's been fine on other movies. But not on this .mp4 movie so was told it needs decryption 1st with passkey but it's really expensive. I just can't see what encryption does anyway
does the sound cut out at some point during the movie ?? if the movie does have cinavia then you can try dvdfab
dvdfab has a free HD Decrypter that works on most movies.
DVDFab Passkey.
OP: If you know how to post a MediaInfo report on the mp4 this should be of use to tell you what type of file it is..SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Perhaps I'm showing my ignorance, it's not an area I delve into much - in passkey similar to anydvd ?
What bearing does it have on an mp4 as mentioned by the OP ?
Passkey of course has no bearing on anything other than removing regional coding on DVD's and BD discs - clearly the OP doesn't yet have the skill set understanding. So the best we can do here is to assist him in a better understanding that's why many people come here for assistance, after all the name of this forum is VideoHelp.
My guess is the MP4 is a fake or even malware who knows? Until a MediaInfo file report is published it's simply conjecture.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
ok here is MediaInfo on the movie in question
Code:General Complete name : D:\downloads_D\movies\Insidious.The.Last.Key.2018.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 993 MiB Duration : 1 h 38 min Overall bit rate mode : Variable Overall bit rate : 1 403 kb/s Movie name : Insidious The Last Key (2018) 720P WEB-DL-X264-MP3-Cr@zyTribal Writing application : Lavf55.33.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1 h 38 min Bit rate : 1 280 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.058 Stream size : 898 MiB (90%) Writing library : x264 core 148 r2643 5c65704 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / lookahead_threads=8 / sliced_threads=1 / slices=8 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=1280 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : mp4a-40-2 Duration : 1 h 38 min Bit rate mode : Variable Bit rate : 129 kb/s Maximum bit rate : 515 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 91.0 MiB (9%) Language : English Default : Yes Alternate group : 1
I bought this utility called CinEx HD Utility http://cinexhd3.com/downloads/ which removes cinavia from movies, I use the program called CinDE shell extention which scans the movies for cinavia then if present use CinEx HD to remove it. so when i scanned the above movie it said cinavia present. so then I used CinEx HD to remove it, but it still said cinavia present. so i asked people i bought CinEx HD from and they said
you have to use either Passkey or AnyDVDHD to remove decryptions make sure they are up to date
they also saidso they are saying I need to use a decrypter on the movie so CinEx HD can remove the cinavia the decryptors clean the title up so we can produce a database to accurately remove CinaviaAll movie titles have some sort of encryption
hope now all this makes sense
AnonymousGuest
Well.. it looks to me a pirate copy of a very recently movie!
We don't discuss this kind of stuff here afaik!
akamai media encryption
By FernandaLobo in forum Video Streaming DownloadingReplies: 1Last Post: 18th Jun 2016, 23:29 -
HTTPS encryption on Yahoo
By Anonymous53584 in forum Video Streaming DownloadingReplies: 2Last Post: 12th Oct 2014, 11:57 -
Downloading HLS with AES encryption ??
By graphics in forum Video Streaming DownloadingReplies: 0Last Post: 14th Jun 2014, 17:25 -
Fed up with Encryption
By timuk in forum Newbie / General discussionsReplies: 3Last Post: 27th Apr 2014, 16:54 -
Trying to record VHS from the 80's (From TV) with encryption? Help?
By AnthraxFan1987 in forum Capturing and VCRReplies: 55Last Post: 25th Oct 2013, 09:48
