Using below command to capture Video8 from firewire camcorder. Video capture is good up to ~4 GB (~20 min) then just a random bunch of pixels on Fedora 27 with EXT4 formatted HDD. What is causing 4 GB boundary? Believe EXT4 has 48-bit addressing so it shouldn't be the drive format.
dvgrab -autosplit -timesys -size 0 -f dv2 Tape1
Not really familiar with Linux or dvgrab, but have you tried it without the autosplit option? https://help.ubuntu.com/community/FireWire/dvgrab
But others here may have better advice.
And welcome to our forums.
I'll remove the autosplit option but suspect the same wrong behavior after 4 GB because I'm getting one big file (11+ GB) for 90+ mins of video. The first 4 GB captured fine but the remaining single file didn't capture properly because it is just a bunch of pixels and no audio.
You need to use the -opendml option with dv2 format.
Anything else to try?
Used the following command and same problem at 4 GB (19 mins & 12 secs) into 25 GB file (~1:50:00).
dvgrab -timesys -size 0 -opendml -f dv2 Tape1
It's an older cpu but appears capable.
model name : AMD Phenom(tm) II X6 1075T Processor
cpu cores : 6
address sizes : 48 bits physical, 48 bits virtual
Is YT video quality really so bad?
By Bernix in forum Video Streaming DownloadingReplies: 19Last Post: 11th Jan 2018, 10:23 -
Elgato Video Capture Virtual Dub Error "Unable to start video capture"
By mountaincabbage in forum Capturing and VCRReplies: 0Last Post: 18th Apr 2016, 14:04 -
Capture looks bad
By solouplay in forum Capturing and VCRReplies: 8Last Post: 13th Mar 2015, 00:52 -
Good or Bad idea to merge GoPro video with prosumer camera video ?
By AAC in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 26th Sep 2014, 03:08 -
Youtube Video looks bad
By shipta in forum Video Streaming DownloadingReplies: 4Last Post: 11th Sep 2014, 15:16
