I downloaded a video from YouTube with VP9/Opus codecs.
But its not well play in VLC and Windows Media Player. I tried Handbrake to encode Vp9 to H.264, but it waste more time and lose quality.
Is any way to i convert Vp9/MKV to H.264/MP4 without re-encoding ?
Why convert it when you can just download the H.264 mp4 from YouTube? Programs like jdownloader and youtube-dl let you select the format to download. There are also websites like keepvid that download the video in mp4.
I purchased a movie on YouTube, which is not downloadable in YouTube -dl /savefrom ,
When i play YouTube from my account, just IDM capture option appears. IDM can download it but not in h.264 /aac, it is download in VP9 which not play well in some other device like TV , also VLC.
Pls. Anyone have a right way to change only codecs ? I don't want to compress it. -
not possible without re-encoding
Figure out another way to download the h264/aac version. For example, you can enter authentication credentials (login/pw)with youtube-dl , did you try that ? -
Check if it is also HDR (you can tell if it is vp9.2).
If it is then you have other problems too like converting HDR->SDR, there's threads around the place lamenting hdr->sdr at the moment. -
look at the help for switches , under authentication options
youtube-dl -h
Code:. . Authentication Options: -u, --username USERNAME Login with this account ID -p, --password PASSWORD Account password. If this option is left out, youtube-dl will ask interactively. -2, --twofactor TWOFACTOR Two-factor authentication code -n, --netrc Use .netrc authentication data --video-password PASSWORD Video password (vimeo, smotri, youku) . . .
Youtube - Not getting VP9 in my latest videos
By stranno in forum Video Streaming DownloadingReplies: 9Last Post: 25th Apr 2017, 17:09 -
How to watch Youtube videos (with h264 codec insead of VP9) in browsers?
By Stears555 in forum Software PlayingReplies: 9Last Post: 26th Aug 2015, 08:01 -
VP9 on Youtube
By newpball in forum Video Streaming DownloadingReplies: 4Last Post: 1st Apr 2015, 18:27 -
youtube to switch to vp9
By deadrats in forum Video Streaming DownloadingReplies: 3Last Post: 1st Jan 2014, 11:53 -
H264 VS. VP9 codec
By Stears555 in forum Video ConversionReplies: 1Last Post: 9th Aug 2013, 09:45
