Hi,
I seem to have a problem with the position of the subtitles when I'm playing an UHD movie with MPC-HC 64 bit with CCCP (LAV codecs + DirectVobSub), subtitles are left aligned and middle aligned vertically (see screenshot).
[Attachment 44881 - Click to enlarge]
Same problem with full screen, I can't seem to override the position by ticking and adjusting "override placement", the subtitles stay in the same position. Override placement doesn't work in MPC-HC nor in DirectVobSub. I have the same problem on another pc. Doesn't matter what movie, I have the same problem with every 2160p movie, 1080p displays just fine. Subtitles are in SDH.
Look where that is: it is rendering as it would with a 1080p image size. So even though the app can stretch to accomodate a 4k image, the rendering of subs is still limited.
The coding needs to be updated. If this isn't the last version of mpc-hc, maybe getting a later version would fix it. If it is the last version, best start looking for a new player.
*Unless the subs format is one that specifies absolute placement, then that could be adjusted. Note: SDH is not a format, but a contextual style/application.
MPC - HEVC 2160p - artefacts with NVIDIA CUVID
By asdrewq in forum Software PlayingReplies: 3Last Post: 24th Nov 2017, 12:06 -
MPC restart from last position
By rojavh in forum Software PlayingReplies: 15Last Post: 10th Mar 2017, 08:53 -
.ts DVB with dvbsubtitles --> mkv with subtitles (wrong subtitle position)
By smellycat3 in forum Video ConversionReplies: 2Last Post: 27th Dec 2015, 17:45 -
MPC-HC subtitle position not working
By sanjozko in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2015, 15:36 -
Opening MPC-HC at a specific position
By mkvideo in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2013, 17:50
