Hello everyone,
I have questions about HandBrake.
1.Is there any way to remove black bar from video without reduce the bitrate? (It's never exceed 20mbps for untouched bluray.)
2.Is there any way to possible remove black bar from lossy video without any compression?
Results 1 to 13 of 13
Sure, specify the same bitrate as your source when you re-encode.
You mean without any re-compression? No. To remove the black bars the video has to be decompressed, the black bars removed, then re-compressed. If you specify the same bitrate as the source you will get a file of the same size. If you use RF based encoding you will get a file of unknown size, ranging from much smaller than your source to much bigger than your source depending on the RF setting. -
By reading the fine manuals.
If you want a GUI, VirtualDub can do it, too. -
22% was all Handbrake did -?
By Arby in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2016, 15:57 -
Besides Handbrake - Any ?
By niteghost in forum Video ConversionReplies: 18Last Post: 9th Nov 2015, 09:08 -
Handbrake Update Has Ruined Handbrake
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 11Last Post: 11th Mar 2015, 13:32 -
Problem with Handbrake
By Cygnus111 in forum DVD RippingReplies: 6Last Post: 30th Jun 2014, 13:26 -
Handbrake help
By SwordNeedsHelp in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2014, 11:21
