I would like to encode with Megui from a 4K source to 1080p x264. But have very pale colors, what do I have to change in the settings?
Video
Format : AVC
Format-Profil : High@L4.1
Format-Einstellungen : CABAC / 5 Ref Frames
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für RefFrames : 5 frames
Codec-ID : V_MPEG4/ISO/AVC
Dauer : 2 h 3 min
Bitrate : 2 516 kb/s
Breite : 1 280 Pixel
Höhe : 688 Pixel
Bildseitenverhältnis : 1,85:1
Ursprüngliches Bildseitenverhältnis : 1,85:1
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 23,976 (24000/1001) FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.119
Stream-Größe : 2,17 GiB (51%)
verwendete Encoder-Bibliothek : x264 core 148 r2708 86b7198
Kodierungseinstellungen : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=21 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Ja
Forced : Nein
colour_range : Limited
colour_primaries : BT.2020
transfer_characteristics : PQ
matrix_coefficients : BT.2020 non-constant
Your source is HDR? x264 doesn't support signalling the required parameters. You could add them on the container level using mkvtoolnix but not all players will support this.
My recommendation:
A. If you want to keep HDR only encode to HEVC/H.265
B. If you don't want to keep you need to do a HDR->SDR conversion (tone mapping). AFAIK MeGUI doesn't have this feature (short of integrating your own AviSynth conversion).
There are solutions for HDR->SDR tone mapping for ffmpeg and VapourSynth. (I think RipBot integrates the ffmpeg solution.)
https://forum.doom9.org/showthread.php?p=1827927
https://forum.doom9.org/showthread.php?t=174415
https://github.com/ifb/vapoursynth-tonemap -
Going to guess it has something to do with your BT.2020 source not being converted to BT.709 when you downsize the resolution. So you have a 1080p BT.2020 video being displayed as BT.709. My experience with BT.2020 is not much but maybe in avisynth put
Code:Dither_convert_yuv_to_rgb(matrix="2020") Dither_convert_rgb_to_yuv(matrix="709")
If he is starting with this, I'd recommend ffmpeg (perhaps easier setup) or Vapoursynth (just video, audio would need to be treated separately), but not Avisynth.
or nvencc (possibly piped from ffmpeg) if she/he has an nvidia card https://github.com/rigaya/NVEnc ?
just right-click and translate the githib page and check the English NVEncC_Options.en.mdLast edited by hydra3333; 12th Mar 2018 at 02:14. Reason: spelling. i'd blame autocorrect if i could
Best x264 settings that you've ever tried
By anana in forum Newbie / General discussionsReplies: 4Last Post: 21st Apr 2016, 23:13 -
x264 compatible settings
By nixiejames in forum Video ConversionReplies: 6Last Post: 31st Mar 2016, 23:04 -
x264 settings for Youtube
By SameSelf in forum Video ConversionReplies: 9Last Post: 25th Aug 2015, 09:10 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 01:14 -
What is the best settings for x264
By mmkk in forum Video ConversionReplies: 7Last Post: 14th May 2014, 11:11
