I am having real problems getting a Good quality SVCD made from material captured through my AIW 7500 card. It becomes blocky or pixilated at higher motion scenes. I've looked through the forums and seems like the only suggestion that I havn't actually done yet that can reduce this problem is doing a 3-pass VBR encoding.. Problem, seems like only CCE can do this and its not cheap and that damn thing Logo makes it not worth it.
Is there any way to get TMPGe, or any other encoder to do a more than 2 pass encoding?
What other alternatives do I have here?
I just want to get a Good quality 44 minute show onto a single disk. Right now it looks like i'm going to have to split them into two disks all the time..
Which program are you using to capture? What capture bitrate and resolution?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I'm using the PICvideo codex (level 19), if i'm present when I want to record I use VirtualDub, otherwise I use the PICVideo codex with AIW's software (like the timer).
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 00:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
CBR vs 2-pass VBR comparison (really 3)
By Quantum in forum Video ConversionReplies: 28Last Post: 2nd Oct 2008, 16:20 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 15th Jul 2007, 00:24 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 19:03
