I'm planning on converting some old video tapes to digital/dvd... just wondering how YOU would go about doing it. No answer is wrong, just want to get some ideas.
I already have a Dazzle Video Capture USB v1.0... all I need are some software ideas. Something quick/simple, all-in-one possibly. The only thing I will need to edit out would be the blue screen between recordings.
Thanks in advance!
Results 1 to 13 of 13
AnonymousGuest
When my 8mm deck died, and "Dr. Sony" failed to fix it completely (I don't use him anymore), I went to eBay and managed to get a NIB Sony TRV-110. It does all 8mm formats: 8mm/Hi8/Digital 8. It has a built-in TBC which, while it doesn't do everything a high-end TBC of yore used to be able to do, definitely does provide some improvements. All video output, whether from analog or digital 8mm tapes, is sent out the 1394/Firewire port, so you can simply capture with Scenalyzer, a bulletproof DV capture app (now free). It is a really easy workflow and once you get the 1394 capture working (I've been told this is harder to do on brand new computers), the capture and editing are as simple as video editing can be.
Last edited by johnmeyer; 9th Mar 2018 at 02:05. Reason: mis-typed the Sony model number
AnonymousGuest
AnonymousGuest
Here's an updated question for anybody reading.
The quality on the TV appears to be 10x better than capturing.
Is it the capture device... software... or both?
Can I get 100% quality ... ?
Any recommendations on capture devices or software would be appreciated! Thanks! -
Perhaps this:
http://www.ezcap.tv/
You should post a small sample of your capture efforts perhaps somebody could offer
more directed advice -
AnonymousGuest
I'm not sure what is wrong... but every once in a while the sound makes voices sound like robots. No need to post a capture.
I don't know if it's the capture device... it must be... because there was no weird sound for an hour when I tried it on TV.
The problem is I don't have the money to buy a new capture device right now.
But I will look into alternatives. -
AnonymousGuest
I'm thinking it might be a driver problem... but I have the most up to date driver installed.
You could read this recent thread, from less than a week ago, here in this forum. There was (IMHO) some bad advice given, but you might still find something useful:
Converting VHS to digital - looks better on TV than it does on comp. -
The EZcap/EZcrap advice is terrible.
The reason why TV is fine, capture card is not:
Originally Posted by lordsmurfWant my help? Ask here! (not via PM!)
AnonymousGuest
Well, you've been given good advice, both by me and by others, and you keep rejecting that device. The advice -- which is given in that other thread as well -- is that you need to include a time base corrector in your capture chain (and other circuitry as well) because if your video looks good on the TV, but not when you capture it, then that is almost certainly the problem. The thread I linked to talks about Macrovision which does indeed create waviness. However, other visual disturbances can also result from using capture hardware that does not regenerate timing signals correctly, even if your tape does not include Macrovision.
So, since you refuse to post a capture, and since you are rejecting all the advice you have been given, you are not likely to get any more advice. -
Can I record Hi8 quality on video8 tapes?
By chinhang899 in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2017, 04:00 -
Capturing Video8/Hi8
By pvrbulls in forum Capturing and VCRReplies: 13Last Post: 12th Feb 2017, 09:31 -
Hi8/Video8 Conversion Questions (Help Wanted, Please!!)
By RyfromNy in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 12:45 -
Camcorder breaking my Hi8 and Video8 tapes
By tradermarco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 26th Dec 2015, 21:59 -
Capturing Video8 and Hi8 - guides
By swiego in forum Capturing and VCRReplies: 17Last Post: 1st Apr 2013, 10:07
