I'm using Virtual Dub to convert a video from 23.976 to 25fps, but I'm not seeing any video. Just the audio.
I did everything. I even made sure the input and output video panes were displayed. I'm still not seeing the video when I save as AVI. The VLC thumbnail shows a video, but again, I'm not getting any video. Just the audio. What am I doing wrong?
You probably only performed the first pass of a multipass encoding. During the first pass a black video is saved. During the second pass the real video is saved.
Okay, so how exactly do I perform the Multipass encoding? Step-by-step. I have the separate video and audio elements ready.
You don't need to convert the avi in virtual dub,just change the frame rate in video from 23.976 to 25 and choose direct stream copy to save.You will need to re-encode the audio to match.
video into Virtual Dub
By lovebug in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2017, 07:25 -
Virtual Dub- audio sync
By shokan22 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2014, 02:23 -
Virtual Dub no audio decompressor found
By shokan22 in forum Newbie / General discussionsReplies: 41Last Post: 26th Jul 2014, 16:32 -
A n audio/fps problem with virtual dub
By shaunxe in forum Capturing and VCRReplies: 2Last Post: 3rd Dec 2013, 01:37 -
Virtual Dub 1.9.11- Capture audio sections and use them in the same video
By vjmehra in forum Video Streaming DownloadingReplies: 2Last Post: 24th Oct 2013, 15:44
