DLG Fox Encoding V.1.69 Beta x32/x64 Tested on Systems Win7 (x32/x64) - Win10 (x32/x64)
● Video Conversion System in the Most Popular Formats.
● Analysis of the Video Resource Loaded With Short And Detailed Information.
● Video Preview System in Input And Output.
● Choice and Edit of the Video Resolution.
● Choice of Video Codecs in Base to the Loaded Video Format.
● Choice and Edit of the Output FPS with AVS Filter
● Index of Control and Video Quality in Output.
● Presets on the Encodings According to the Codecs Type.
● Choice and Edit of the Output Aspect Ratio.
● Choice of Audio Codecs in Base to the Loaded Video Format.
● Choice and Edit of Audio Channels.
● Choice and Edit of Audio Bit-Rate.
● Choice and Edit of Audio Sampling Rate.
● Deinterlace Video Filter.
● Denoise Video Filter.
● Non-Local Means Video Filter.
● Deblock Video Filter.
● Video Rotation Filters + Flip.Vertical & Flip.Horizontal.
● Choice : Sample Aspect Ratio (SAR) & Display Aspect Ratio (DAR).
● Detect Video Cropping Filter.
● Image Capture From Video With System *KSF (Keep Snap Frame)
● Video Image Filter (Brightness, Contrast, Saturation, Gamma, Grayscale)
● Video Cutting System with Start and End Preview.
● A/V Sync Filter for Track Alignment Out of Sync.
● Manual Setting of the Starting point of the Video Track and Final Video Length.
Public Beta Test.
https://github.com/AlexMalkovich/DLG-Fox-Encoding/wiki/DLG-Fox-Encoding-v1.69
Last edited by Malkovich; 7th Mar 2018 at 15:58. Reason: Added Short Information of "Fox Encoding" Before Clicking on the Link ... Thanks to @LigH.de for its Meticulous Attention.
« I Mediocri Imitano, I Geni Copiano, Dio Crea » (Io Perfeziono Il Loro Lavoro) -
For those (like me) who would like to know what to expect before even clicking a link:
It appears to be another allround and all-purpose media converter. Cool looking, maybe. Powerful, probably. Hopefully not related to the Fox Entertainment Group ... rather using a cute fox icon as mascot. -
Tested on Windows 8 32bit:
Not a good start:
Installer playing music? (luckily can be stopped in the upper right corner)
No Default install dir? (Choose: 'C:\Program Files\')
Program folder name itself can't be named an then the version name inside the name? (now got: 'C:\Program Files\DLG Fox Encoding v1.69')
-> Then the Installer ended with:The Readme_ENG.pdf stated: 'Systems Win7 (x32/x64) - Win10 (x32/x64)', so I thought Windows 8 would be okay,...ERROR: Wrong Arch. File to Replace \*DLG ...
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
@Selur ... Make sure that once the zip content is extracted, together with the Setup.exe there are also the archives "FE169a.dlg" and "FE169b.dlg".
Can someone help me download from FOX ?
By TheRandomOne in forum Video Streaming DownloadingReplies: 28Last Post: 16th Dec 2016, 20:46 -
Red Fox Website Down
By wulf109 in forum Blu-ray RippingReplies: 15Last Post: 23rd Jul 2016, 19:58 -
Fox.com Grease Live
By mcdanielsamuel in forum Video Streaming DownloadingReplies: 9Last Post: 5th Feb 2016, 14:29 -
Can anyone help me get this fox news video please?
By jramirez92 in forum Video Streaming DownloadingReplies: 8Last Post: 9th May 2015, 05:58 -
From Digi Beta or Analog Beta to MP4 keeping CC
By andreschapero in forum Video ConversionReplies: 1Last Post: 3rd Dec 2013, 00:57
