Hi all,
I have been using TMPGEnc to make DVDs and have been quite happy with the results. Yesterday I got what looked like compression distortion (pixilation?) on the face of someone moving towrd me, and quite close. As she moved closer her face was broken up into obvious blocks. As she passed the blocks went away.
I have been using the defaults and wizzard to set up an MPEG2 for a standard DVD. Has anyone seen this before and have an idea how to prevent this from happening?
Thanks,
Michael
Try turning up the minimum bit rate. I've had better luck around 3000. From what I understand some DVD players may have problems above 2600, tho.... Try it and see. Turning it up has seemed to help some pixelization I've seen in slower scenes....
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
