Hello!
I wanted to re-render the Fim from a DVD because I had sound on the computer (with VLC) but not on a DVD player.
So I downloaded the directory, from the DVD, and renamed the files VTS_01_01.VOB => VTS_01_04.VOB to VTS_01_xx.mpeg.
Now I have imported the files with "File load". They lie one behind the other in a lane.
It will display a total length of 26: 40: 00: 00 (it would be accurate to about 1:34 hours) and the files are shortened
How do I get the time displayed correctly and the files displayed without any shortening?
A picture of it lies here: http://www.cshare.de/file/0863c2d000c2f6f7f5e5f9ab86985102/Bildschirmfoto_2018-03-05_1...43-48.png.html
With kind regards R. Lehmeier
You could try with winff or handbrake to produce a solid mpg file and load that in cinelerra
Or try this
VOB format is a subset of mpeg, so you should be able to combine the VOBs you want to read in just as you would mpeg data: by concatenating them together.
cat first.VOB second.VOB third.VOB | ffmpeg -i - outfile.mp4
Hoisting Matt Gallagher's comment to increase longevity/visibility:
Newer versions of ffmpeg support concatenation as an operator on the input file. So you could use... ffmpeg -i concat:VTS_01_0.VOB\|VTS_01_1.VOB\|VTS_01_2.VOB outfile.mp4Last edited by jan5678; 5th Mar 2018 at 15:55.
Thanks for the tip, but it shrinks the file size.
But it should stay the same.
How can I adjust it so that the amount of data remains the same. I would like that the picture quality does not deteriorate.
In the manual of ffmpeg I find no indication - or have I overlooked it?
It is displayed when rendering that the buffer size is not specified and thus is set to 130 kb, it may be because or is the bitrate too low ??
Sincerely, R. Lehmeier -
No experience with Cinelerra under Manjaro but I use 'Flowblade' under KDE and it imports and edits .ts files directly without renaming. I often edit and join dozens of clips in .ts wrappers and it does seem to keep the overall length and time codes intact. I think Flowblade should load without problems in Manjaro if you want to try it.
Brian. -
I do not think that it is the Cinelerra.
I assume that the files are broken.
On a DVD player everything is fine (but without sound), on the computer I have sound but not all chapters are displayed.
The files are quite large and have only a short runtime:
1. VTS_01_1.VOB (1.07 GB, Time 6:28:13 min),
2. VTS_01_2.VOB (1.07 GB, time 1:51:10 min),
3. VTS_01_3.Vob, 1985 MB, Time 5:05:08 min)
Since this is a normal DVD (720x576 25 frames / s) does not seem to me right.
How can I repair the files so that all chapters work again?
Need help using Cinelerra Motion for image stabilisation
By DeJay in forum LinuxReplies: 15Last Post: 28th Jun 2017, 07:38 -
Cinelerra video editor [Linux]
By racer-x in forum LinuxReplies: 4Last Post: 13th Apr 2017, 01:37 -
Problems Demuxing, Remuxing and Encoding AVIs. Also MeGUI problems.
By VideoFanatic in forum RestorationReplies: 1Last Post: 10th Feb 2016, 02:30 -
Time lapse in Vdub. Problems with large file size and x264VfW problems
By nab49 in forum Newbie / General discussionsReplies: 18Last Post: 24th Sep 2014, 16:52
