Hello:
does anyone know where in Win7 Sony put the preferences folder that would store any additional entries that one makes in the main program to such options as the EQ, the Fade option & others?
I've looked in both the Sony folders I've found in either user/appdata local or roaming & can't find it.
I have to take down my original op/sys & I'm rebuilding a new op/sys. The sound forge program is up & running in the new op/sys but I have to transfer over these preferences to the new op/sys before I dump the old system, there are so many of these little entries. I cannot afford to lose them, I'd never remember them all.
thx in advance
Use Procmon to determine where the settings are saved.
https://docs.microsoft.com/en-us/sysinternals/downloads/procmon -
Can Sound Forge not open MPG / VOB files?
By guy24s in forum EditingReplies: 14Last Post: 17th Dec 2017, 03:50 -
How to batch split mkv in different folder to another location?
By yusoffb01 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2017, 07:30 -
How to remove click and crackle from a VHS audio using Sound Forge?
By KortschKo in forum RestorationReplies: 7Last Post: 16th Feb 2016, 18:57 -
[Sound Forge] working in very long audio file using regions & marks?
By moghbr in forum AudioReplies: 0Last Post: 30th Aug 2013, 07:08 -
Sound Forge Audio Studio - No Sound From Recording
By Teac23 in forum AudioReplies: 6Last Post: 12th May 2013, 20:22
