Page 8 of 19
FirstFirst ... 6 7 8 9 10 18 ... LastLast
Results 211 to 240 of 568
    Jun 2018
    Australia
    Hey
    You mention Oppo 203(mine is Jaibreaked). does this allow perfect playback of BDXL disc with no problem at all including 66gb & 100gb please
    how do you jailbreak the oppo 203 and does it cost anything or can cause the machine to not work if done properly
    cheers
    Kadu
  2. Originally Posted by Kadu7475 View Post
    Hey
    cheers
    Kadu
    Where are we in being able to play BD-XL discs?
  3. Verbatim's white inkjet printable BDXL worked in the Panasonic DP-UB150-K. Player firmware version is 1.04. PS5 and Series X unable to recognize the disc. Thanks.
    Feb 2006
    according to this - https://www.playstation.com/en-us/support/hardware/ps5-problem-reading-disc/
    the playstation 5 does not play burned discs or audio CDs.
    Nov 2020
    Israel
    Mine is UB450 with ver. 1.15. does not read any BDXL.
    its supposed to be the same unit with only DV. it even uses the same firmware. maybe there's a way to downgrade and check.
    Jun 2018
    Australia
    Hey Per 1971
    cheers
    Dec 2019
    Canada
    Dec 2019
    Canada
    Nov 2020
    Israel
    Hey Per 1971
    cheers
    My Oppo 203 reads BDXL beyond the 66GB mark, but only under these conditions: Verbatim M-DISC in Jawl case only (5 Pack or singles) no cake packs or non M-Disc, burning at x2 (No x4 or 2.4) with IMGBurn only. no need to jailbreak the Oppo 203 for this. works the same after jailbreak or without it.
    Works 90% of the times and only if the disc is burned to all 3 layers (70-80GB). movies that was on 2 layers only was freez at the layer break and i had to skip a chapter.
    My UB450 (which i bopught recently) didn't read any of my BDXL's and if someone can provide a solution to downgrade the firmware from 1.15 to 1.09 it will be helpfull.
  10. Originally Posted by bouchnouk View Post
    verbatim's white inkjet printable bdxl worked in the panasonic dp-ub150-k. Player firmware version is 1.04. Ps5 and series x unable to recognize the disc. Thanks.
    i forgot. What was the size of the disc?
    77 gb
    Dec 2019
    Canada
    Dec 2019
    Canada
  13. I thought adding custom firmware to make certain BD-ROM drives UHD Friendly only allowed the ripping of UHD discs?
    Nov 2020
    Israel
    Yes i got UHD friendly Drive LG WH16NS40. The UB450 thing is very frustrating as it should be the same as the UB150 that reported working with BDXL.
    Dec 2019
    Canada
    Dec 2019
    Canada
    Feb 2006
    to downgrade the firmware, see here - https://forum.dvdfab.cn/forum/uhd-copy-ripper/364290-uhd-drive-tool-v2-supports-ahci-i...usb-connection
    the product - https://www.dvdfab.cn/uhd-drive-tool.htm
  18. Member
    Dec 2019
    Canada
    Nov 2020
    Israel
    The firmware problem is in the player (UB450). Not with the PC drive.
    Sep 2020
    SWEDEN
    Hey Per 1971
    cheers
    Hey !
    Sorry about the delay.
    I´ve tried mine on 1,2 and 3 layers BDXL discs(only Verbatim) and they work fine.
    It might do a hiccup bteween layers, but mostly not.
    BUT it might take up to 60 seconds to load the disc.
    It can also say "Unknown Disc", but eject and try again and again...
    My worst case was ejected 3 times before playing !
    The JB itself can be dowloaded at another forum( will send you a PM with the link).
    Its done with a USB stick, very easy, and works great !
    //Per
  21. I have a ub9000, so would there be any way to get the Japanese firmware to play bdxl discs?
    Also is there any way to get a blank type of disc that UHD Blu-Ray uses to avoid this whole mess lol
  22. Member
    Nov 2020
    Israel
    A Little update
    All my previous BDXL Burnings were using LG WH16NS40 Burner connected to SATA on motherboards. since i have experienced some cases of layer break freezes on BD-50 as well (weird i know) i have investigated a little. i got an older BD Burner (Pioneer) connected to USB that doesn't support BDXL but burn my BD-50's perfectly. i have bought a third burner, the ASUS 16D1HT which i herd is a very good BDXL burner. i have connected it throgh USB (Externaly) and not SATA (Internaly) and i burnes 2 BDXL discs at x2 speed. those disc played perfectly from begining to end through my Oppo 203 and for the first time EVER were played with my new Panasonic UB-450, That have never played any of my BDXL burning before.
    I really don't know why it's working better through USB but it did, so i wanted to share
  23. Originally Posted by rick090 View Post
    A Little update
    Were the BDXL discs that didn't work burned at the same 2x speed? I experienced disc recognition issues with the UB-150 with a disc burned at 4x
  24. Member
    Nov 2020
    Israel
    Yes all of them always burned at x2. my first 2 ever were at 4x, i didn't know better. the slower the burning speed, the lower read problems. but x2 from usb connected burner was perfect.
  25. Originally Posted by DylanValenti View Post
    I am seriously doubt that it is possible to install the firmware of a Japanese device on a player of another region. The Japanese firmware does not even have the ability to change the language, all menus and submenus are only in Japanese.
  26. Originally Posted by rick090 View Post
    A Little update
    Was it actually BDXL and were the files burnt more than 66 Gb (2 layers)?
  27. Member
    Nov 2020
    Israel
    Off course it was BDXL. 2 discs filled with more than 80GB each, played from begining to end with no glitch inc. Bonus features.
    By the way, i don't think there is actually a 66gb limitation on any player. first of all the layer freez accure at the first layer transition to the second, so it's the 33GB mark and not 66GB. my oppo 203 never had problem swiching from second to third layer (from 66gb to 99gb) only the second layer had freezes.
    when burning at x2 from USB connected burner, no freez on any layer, and as i said, the discs working on my panasonic UB450 as well and its the first time i managed to play BDXL on this player.
    on both players i can get "Disc not recognized" kind of error when inserting a disc, but second and third try and it plays. and when it start playing its playing perfectly.
  28. Originally Posted by rick090 View Post
    Ok. Will try to burn at x2 speed and then to play at Oppo 203.
  29. Member
    Nov 2020
    Israel
    But connect the burner to USB port. that is the magic trick for me
  30. Member
    Sep 2018
    France
    Hi, to recap :
    Pana UB450 can read BDXL 3x layer with a burner ASUS 16D1HT connected in USB ?
