What discs are you using?
Results 31 to 60 of 568
Looks like you have a failed burn, or at least one or more sectors did not write properly or imperfections in the disc made it impossible to write to that sector. If this popped up during verification (not during the burn) then most of the disc is probably still readable but it has errors. Best this to do is to try and burn again with a new disc. If you keep getting errors you might consider blowing compressed air in your open drive to try and get any dust off the laser.
Sure ? Is it a report or result of your own experience ? If real, it's a very bad news ! With Panasonic, I need 2 players : one for BD-R XL reading (UB900) and one for DV, HDR10+ aso reading (UB820)... I don't understand why "downgrading" a capacity like this ! Unless it is the reader himself who can not read BR 3 layers while that of the UB900 could ...
Not my own experience. In Mundodvd a spanish forum people who have it have reported that they donīt work.
what software and settings do you use to burn the bdxl??, I use imgburn but in the 3 recordings that I have made, they are played in jumps with my Panasonic UB900
Regards. -
[QUOTE=zizux;2523840][QUOTE=jangai;2523815] I use Imgburn with Windows 8 running as virtual PC on an Apple PowerMac 2013. Burner drive is an USB3 known as "Matshita" BD-MLT UJ272 1.02 and software is Imgburn 2.5.8.0 (UDF 2.5, I believe) burning TDK discs.
More info by MP if yo ask. -
Gosh !
Today i've got the firm and verified answer from Panasonic France After Sales:
DP-UB820 does not support reading of BD-R XL !!!
So, I keep my DMP-UB900 and wait one day in the future a Blu-Ray XL player builder give us a good dynamic HDR player (Dolby Vision and others) which could ALSO read ALL BD-R standards so BD-R XL...
Whoever has better information on this topic will be welcome on this thread ...
I wouldn't take that as being a definitive answer.
I purchased the Sony UBP-X700 a few months ago only to find out that the player would not read a BDXL disc I'd written to. I contacted Sony customer support who said that the player did not support these discs. A few weeks later I saw on another forum that someone had written to just the first 2 layers of a BDXL-R disc and successfully played that back on the Sony. I then tried this myself and can confirm that the Sony will play back BDXL-R discs providing that you only write to the first 2 layers.
I suggest that we wait for an owner of the DP-UB820 to confirm whether playing a BDXL-R disc works on that player. -
Yes, you are right: it is not impossible that the answer that was given to me by Panasonic comes from a simple reading of a spec sheet ... But the specifications of the UB900 do not quote the BD-R XL and yet, he recognizes them! Maybe Panasonic UB9000 as worthy successor of the UB900 at the top of the range will like him to recognize and read the BD-R XL which are still from the specifications of the "Blu-Ray Association" ? To be continued...
we have 3 new panasonic 4k bluray players launching shortly
Ultra HD Blu-ray Player DP-UB320
Ultra HD Blu-ray Player DP-UB420
Ultra HD Blu-ray Player DP-UB820
I have emailed panasonic to see if they will playback bdxl
I also found this information too
What is BDXL?
The BDXL format supports 100 GB and 128 GB write-once discs and 100 GB rewritable discs.
BD-R 3.0 Format Specification (BDXL)
Defined as a multi-layered recordable disc in BDAV format, with speeds of 2X and 4X. It is capable of 100/128 GB storage capacity and usage of UDF 2.5/2.6 as file system.
BD-RE 4.0 Format Specification (BDXL)
Defined as a multi-layered rewritable disc in BDAV format, with speeds of 2X and 4X. It is capable of 100 GB storage capacity and usage of UDF 2.5 as file system.
From what I read on the specs on the panasonic machines it shows.
BD-RE/ BD-RE DL (Ver.3)
BD-R (Ver.1.3) / BD-R DL (Ver.2)
I am thinking that the new pioneer machine coming out later this year will have bdxl as pioneer were the company who created the 1st bdxl 4k bluray burner for pc.
can't see no reason why they can't use the same drives in the bluray player as they do in PC
so I'm not sure as yet. -
hey everyone
can anyone 100% confirm if the DMP-UB900 can playback bdxl disc properly without glitches or issues with freezing due layer changes.
at present from what i have read only the sony x700 will playback 66gb fine. -
The other dayI bought a Panasonic UB900 and I havenīt got the BDXL to work well, it reads them but they are pixelated and cut. In the end I have changed it for a Sony x700 and all the BDXL up to 66GB reproduces them without problems.
Thks to Oakeyt for the advise. -
Just purchased a Panasonic dmp-ub900 and this plays a verbatim -r bdxl disc perfectly with the content size over 75gb - copy of blade Runner 2049 4k uhd blu-ray.
Happy days! -
Using the latest firmware v1.80.
Not sure why some people have had playback issues using bdxl discs but as yet i haven't had any problems.
Managed to pick mine up for Ģ199 from the official panasonic shop on ebay. Although refurbished, it looks like new and has a 12 month panasonic warranty. -
Hi,
Anyone have tried BD-R XL 100GB discs in a Sony UBP-X800 North American model? -
Hi guys i am new, meanwhile, a greeting to everyone, then I wanted to say that I own a sony x700 and that the reader is not able to read bdxl.I have personally burned 100gb tdk discs, ie 3 layers with my lg 16nu50 burner in both 100gb and 66gb format, to be precise, the film was about 60gb and the table reader does not read them.
That's why I wanted to know how he did, Oakeyt, since he works, sorry for my bad English, and thanks in advance to everyone. -
Yes ! I can confirm : I have one ! I read for months BD-R XL TDK or Verbatim burned with a PC Pioneer drive without any difficulty!
The problem is that this end-of-life player will never decode dynamic HDR Dolby Vision let alone the HDR10+ and will stick to the static HDR10 ... This is my reason to search for a newer player... -
I can see why the makers of UHD Blu-ray players don't claim that their products support BDXL playback. BDXL playback is too inconsistent for them to claim support even when it is possible. If a player plays BDXL media at all, only some brands of BDXL media are playable and the compatible brands vary among UHD Blu-ray players. Plus, even though the specs for UHD Blu-ray allows up to 100GB per disc and the capacity of BDXL is 100GB, the size of a burned ISO file must not exceed 66GB in order for UHD Blu-ray on BDXL to be playable.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Agree with your view on inconsistencies and compatibility. However, please note that the panasonic dmp-ub900 will play back burned uhd bluray on bdxl upto 100gb - I've proven this uding my ub900.
Oakeyt, I do not know what to tell you, I was checking what the words said when I inserted the disc that roughly said so: disk dirty or incompatible as it is not supported, suddenly the miracle works again It works, it reads the tdk disk 100gb, I took a picture let's see and I can load it.
I can confirm that it works perfectly, just use only the first two layers, settings for burning 66gb the film was about 60gb. For the 100gb that is the three layers burned a film with about 81gb is not seen, I tried more times to put and remove the disk but it does not work. The Sony x700 read It. A greeting everybody.
Hi guys
Just bought the little Sony X700 only to burn and play my UHD BD66.
First one, no luck.
I burned Avengers UHD, 58gb, with my Pioneer BDR 209EBK, using Verbatim BDXL (code VERBAT-IMk-000), and the Sony says initially unknown, it ends saying disk might be dirty or session might had not been closed.
I used imgburn, moved the BDMV and Certificate folders to imgburn, which recognized it was a BD Video structure, burned at 4x, took more or less 1 hour.
Iīm gonna try again creating an ISO with DVDFab, i will be using now the Asus BW 16D1HT, which i currently have running UHD friendly firmware, and see if it works this way.
Can you guys detail exactly how you burned your working BD XL?Last edited by cesarleeds; 29th Aug 2018 at 09:24.
Look in the imgbur log for any errors. I always set verify so it compares the disc I've just bured to the source folders.
As yet only had one coaster from roughly 5 burns. All successful burns read ok by the sony.
Never needed to burn from iso, burning from folders not a problem. -
Why bluray player doesn't read the bluray disc?
By mastersab in forum DVD & Blu-ray WritersReplies: 5Last Post: 31st Dec 2017, 08:12 -
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
Is capturing a non-copyrighted bluray off of a bluray player illegal
By ezcapper in forum Capturing and VCRReplies: 13Last Post: 30th Jun 2015, 23:59 -
Bluray player that support bd-iso with full menus
By fits79 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 25th Oct 2014, 00:25 -
Does Bluray support SD Progressive?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 7Last Post: 1st May 2014, 12:48
