Results 511 to 540 of 568
Transporter 3 is not BD-66. It is BD-100. See here
https://www.blu-ray.com/movies/Transporter-3-4K-Blu-ray/206289/
The total size should be roughly 61.5gb or less so it is written only to the first two layers. -
Hello, verbatim records 100gb have to be from Japan, they can't be from Europe? and they can also be bd re or only bd r?
From the Export Only / shipping to the voltage converter requirement to the cost to the constant need for translation -- this is way more than I'd care to have to deal with. I'm very content with my Oppo BR decks. Longer term, ALL disc formats are or will be in decline. (The end of Netflix disc rentals, nothing in the marketplace to fill that void.) And burning the successful high capacity disks is a pain, although I think that part would be within reach with the gear I have on hand.
There is almost nothing I really want to see that can't be found as a video file -- even up to 2160P -- with some diligent and experienced searching online. So I think I will leave this to the high-end domestic market in Japan, and a few maximalist devotees here.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I compared the price of Verbatim BD-R 100GB, buying from Amazon is more expensive than buying from Japan including shipping cost, that's the reason why I bought from Japan, the reason why Blu-ray disc is cheaper in Japan is probably because Blu-ray disc is more popular in Japan than in the US.
Hello.
A new version has been released. Version v1.22 (Dec 13, 2023 Ver 1.22 Stability of system). Has anyone tested if this or v1.21 solved this problem, after 5 minutes paused, when you continue playing it seems to jump for a few seconds?
As well as confirm if it does not affect the playback of BDXL Discs at all.
All the best. -
I bit the bullet and updated to v1.22. No issues playing BD-100. Tested Dolby vision, chapter jump etc.
BD-66 stuck after few seconds as before. BD-50, BD-25 and mkvs play as usual.
Disc reading speed seems to be improved. Not sure what they fixed in this release.
Haven't paused during optical disc playback for that long. I will give it a try. But best option is to stop and resume play after 5 minutes. -
Though DMR-ZR1 can play all discs, $2500 is too much for a player. I don't think my other home theater gear (projector, receiver, speakers etc.) is capable of fully utilizing the quality of this player.
Believe me, DRM-ZR1 has the best picture quality over all other blu-ray players. Read this link (but use the translation because it is in Japanese) https://online.stereosound.co.jp/_ct/17503241
Great, thanks!
I have a suggestion and am curious what you guys think. With these big 66+ GB files, could an option be to split them into two files and burn them on two seperate BD-DL discs and then play them on a 4k player separately? Should that not output the same image and sound quality, or is there something in the BD-XL and official 4k release disc that offers higher resolution and audio? Basically, are 4k and BD-XL discs just a way of storing more data or is there something in the technology that increases the overall quality? -
It's just storage. BDXL is just bigger. No magic!
And, yes- you could split a movie and have it on two smaller discs. -
I think I should have the capability to rip just about any uber-HD-disc to the computer. (But probably wouldn't buy said disc in the first place.) Then I'd convert it to the more earthly size / format that my Oppo BR decks could handle. But then, I'm not someone who is living in the video stratosphere.
Why bluray player doesn't read the bluray disc?
By mastersab in forum DVD & Blu-ray WritersReplies: 5Last Post: 31st Dec 2017, 08:12 -
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
Is capturing a non-copyrighted bluray off of a bluray player illegal
By ezcapper in forum Capturing and VCRReplies: 13Last Post: 30th Jun 2015, 23:59 -
Bluray player that support bd-iso with full menus
By fits79 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 25th Oct 2014, 00:25 -
Does Bluray support SD Progressive?
By VideoFanatic in forum Authoring (Blu-ray)Replies: 7Last Post: 1st May 2014, 12:48
