    Jan 2004
    Earth
    I bought some VHS tapes, and would like to digitize them. From what I read I require the following, VCR, a method (hardware) to defeat copy protection, and a capture device.
    Can you make recommendations for the proper gear? The capture device should be USB ( 3.1/3.0/2.0 are all okay), I will order everything from the US portals of eBay and Amazon since all my tapes are NTSC.
    Thnx in advance,
    *edit* I just would like to add that the capture device should support capturing in a lossless format, later I will encode to x264 with custom settings...
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You need to worry about the PAL/NTSC aspect of things first.
    NTSC tapes can be VIEWED easily in Europe.....but capturing them in Europe is NOT EASY.
    Jan 2004
    Earth
    I am not really worried that much since I am getting all the gear from the US, and will capture on my desktop...so why should I care about the NTSC/PAL issues ate all?
    *edit* Are these good/bad?
    JVC SR S365U
    DataVideo TBC 1000
    Dazzle DVD Recorder -Does the software supports lossless capture?-
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Personally I use the Hauppauge USB|Live2 to capture.....but a computer "card" would have been my first choice....but my original Hauppauge capture "card" only does MPEG2 and cannot capture PAL60(NTSC tape in a PAL VCR).
    I have an NTSC VCR here in Europe but it's crap.
    Oh....and that JVC looks a lot like my Philips VR1100 VCR....most later Philips VCRs were JVC clones in Europe.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the problem is usually the 50 vs. 60 htz of the ac current. us vcr.s cant handle europe's 50 htz current. converters don't help.
    May 2014
    Memphis TN, US
    Originally Posted by mtamimi View Post
    JVC SR S365U
    You'll be very sorry if this player doesn't have a line-level tbc. I don't think it does.
    DataVideo TBC 1000
    Ok if it actually works and you don't mind some image softening.
    Dazzle has always been crap. It's still crap. it will be crap tomorrow.
    - My sister Ann's brother
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I ran an old Philips DVD recorder here in Europe with a relatively cheap power converter, never had a problem with it.
    It died of old age/natural causes.
    JVC SR S365U
    It does not.
    DataVideo TBC 1000
    The model doesn't soften the image. Some copies, yes. But the model, no.
