  1. I have captured some video using the Huffy codec on my ATi AIW card.
    When i now try to convert it to mpeg1 (vcd) in TMPG the audio and video gets out of sync. How can that be?.. the avi file is fine.
    I havent experienced this when converting from any other format before.
    my pc is a 1.4ghz P4
    any help would be great.
    Stupid tv!, be more funny!
  2. What frame rate did you use ?? To use a vcd template, you need to capture at 23.456(Film NTSC), 25 (Pal) or 29 (NTSC)
  3. When using HuffyAVi in the tv-tuner software there is no option to change the framrate, so unless its 20 or 15fps by default it should be fine right?.,.
    i mean, it should also be possible to convert one framerate to another ?
