Hey guys, I hope someone can help me out. I'm getting a bit frustrated here. I'm trying to set up my PS4 Pro to work with this HDMI switch. I'm pretty sure my dad and I have everything connected correctly, but the problem is i'm only seeing 1080p on our Sony XBR55x930D, supports 4K HDR and the game i'm trying to play is Resident Evil 7 Biohazard which is a PS4 Pro enhanced game, meaning it is HDR capable.
I've switched the cables around, played with the setting on the TV and PS4Pro, I just can't get it to the HDR setting, like it's greyed out and it wont let me. Any help is appreciated.
Do you have a ps vr? If so just know it will disable hdr unless you plug you ps directly into the tv - https://gamefaqs.gamespot.com/boards/932981-final-fantasy-xv/74639987?page=1
also check what hdmi port you are using. the hdmi 1 port on many uhd tv is where the hdr option works on . its usually the first HDMi port for most 4k uhd tvs. -
Yes, I have a PS VR that I connected also. Ok, thanks for the advice, I'll take a look and try your suggestions.
HEVC HDR to x264 non-hdr
By mmace in forum Video ConversionReplies: 3Last Post: 20th Nov 2017, 11:19 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 21:03 -
Avermedia Game Capture HD II showing interlacing artifacts on playback
By Fadedown in forum Capturing and VCRReplies: 6Last Post: 22nd Aug 2015, 17:57 -
1080p (60p) Recording from Sony HDR-CX290 looks grainy
By jtdude100 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Jan 2014, 18:06 -
Making a 1080p game video - feeling choppy?
By Artas1984 in forum Video ConversionReplies: 27Last Post: 5th Aug 2013, 17:05
