i have this video my mom took with a tablet and the mic picked a lot of buzzing noise.
is there a way to clean it so i could hear the person speak more clearly ?
As already advised to you can use notch filter (perhaps there is preset like 50Hz ground loop hum removal) or you can use general FFT filter where you can remove signal around 50Hz and 50Hz harmonics - i think you can safely remove everything bellow 160Hz, then 200, 250Hz and as seem this is rectified 50Hz sinewave then your next candidates are separated by 100Hz so 350, 450, 550 till around 1350Hz. Next step is audio normalization with perhaps compression to make speech more legible. I would also filter everything above 8000Hz - not much there, mostly noise.
btw i also recommend to convert your sample (stereo) to mono, conversion should be done in digital domain with 100% 100% mix - you will double signal level and slightly reduce noise - such content is usually anyway mono.
Which are the free alternatives to VideoReDo's "QuickStream Fix" function?
By falco2000 in forum Newbie / General discussionsReplies: 10Last Post: 19th Mar 2022, 16:19 -
how to fix "HTTP error 403 Forbidden - Bad Token!!!"
By tom-vin in forum Video Streaming DownloadingReplies: 11Last Post: 16th Apr 2016, 09:26 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
"Any Video Converter" flips my subtitles upside down. Fix?
By chapelhillfiddler in forum SubtitleReplies: 3Last Post: 20th May 2013, 12:32
