Results 1 to 11 of 11
  1. hi
    Please help
    I would like to update it. Is there an update for this version?
    LG GH24NSC0
    Mar 2008
    Did you look on the LG site?
    As far as I can see, there is no update for this model
  3. Originally Posted by davexnet View Post
    Did your u look on the LG site?
    There is no site
  4. [QUOTE=davexnet;2513344]http://www.lg.com/us/burners-drives/lg-GH24NSC0-internal-dvd-drive[/QUOT
    But how here is no download link update
    Feb 2006
    [QUOTE=COOLKEV;2513393]
    Click on software & drivers then put in the model number of the drive.
  6. Does not exist GH24NSC0
  7. Also looking for firmware update. The 2017 ones use LI00, 2019 ones use LY00. Both have different SVC codes; NSD0, JR23, does this mean the firmware are not compatible with each other?
    Aug 2006
    If you can't get a definitive answer here, try myce's optical drive forum: https://club.myce.com/c/cd-dvd-and-blu-ray-writers
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    myce (cdfreaks) is basically dead. not much going on there.
    Aug 2006
    There are a few threads started in mid 2019 or later in the burner subforum I linked to, so I don't think it is accurate to pronounce it dead yet.
