Im trying to import an avs script in premiere with no success
Can anybody help me step by step on how to import my script in premiere cc 2015...
Results 1 to 30 of 31
I use Debugmode FrameServer with Adobe Premier and if you search in the forum you will find out how to do it, all the best
You can use AVFS (avisynth virtual file system) . Do a quick search there should be guides
But often you're better off using intermediate files (lossless or near lossless), especially if you have slow scripts
That is for exporting, not importing -
Isn't Debugmode Frameserver to export from Premiere? Sounds to me like he needs the opposite: tool to import AviSynth. Like AviSynth Virtual Filesystem (avfs). Latest (newer than that on videohelp) avfs is now included in VapourSynth package AFAIK.
[QUOTE=poisondeathray;2513330] You can use AVFS (avisynth virtual file system) . Do a quick search there should be guides
Yes i have heard about this AVFS and i might give it a try
So does that mean it has the ability to mount the script as an avi or dummy virtual avi so premiere can then recognise it?
Do i need to configure AVFS or is it good to go?
So how does one mount the script as an avi? -
Save your sanity. Don't do it. Go lossless or near-lossless, keyframe-only intermediate.
Or maybe you can find an example of AVFS being used successfully over the long term, doing actual work... I can't
https://www.google.com/search?q=avfs+file+system+adobe+premiere
(EDIT happy to be corrected by poisondeathray below!)Last edited by raffriff42; 28th Feb 2018 at 18:18.
No it's good to go. If you use the most recent one, it's bundled in the vapoursynth package as sneaker mentioned, then it's commandline
And the "fake" avi will appear in c:\volumes and some subfolder according to the avs nameCode:avfs.exe script.avs
But if you use the original pismo file mount , that can be accessed by right clicking the avs, and selecting PFM mount . I keep that for 32bit avs and scripts, the 64bit version for 64bit avs+ scripts
I have used it successfully, over the long term, for years. But only for short projects. You can also load vapoursynth scripts this way
It's not suitable for large projects, or if you have dozens or hundreds of clips. Lossless / nearlossless intermediate is 100x better for editing . There is a lot of overhead in frameserving through avs and into the fake avi and into PP . It's slow. And if you have a slow script filters, it's very very slow. Also, the command line version will keep open a cmd window until you ctrl+c exit ; so if you have 10 avs loaded, that's 10 extra windows.
99% of the time I prefer a digital intermedate. And newer versions of PP treat lossless x264 as true lossless now (including YUV in 8bit, 10bit, different subsampling configurations). You can configure it as I-frame, or longer GOP's for more compression. Other lossless YUV codecs are not treated as lossless in PP (they get conveted to RGB). Also there is an EXport plugin , voukoder , which can use libav/ffmpeg to export various things directly, like libx264/libx265 -
ok I tried installing Download VapourSynth r43 64-bit but keep getting No suitable python 3.6 installations found.
I take it that I need to download install from here https://www.python.org/downloads/release/python-348/ -
I prefer if you just continue in the thread. Because other people might be having the same issues getting it running, and they can get help too by reading the thread
Don't bother installing python , or vapoursynth if you're not going to be using those. I packaged up avfs.exe from R34 x64 and uploaded it here . But you might need the x86 version for x86 scripts, not sure about that, I only have 64bit vapoursynth. For x86 scripts I use the pismo mount method. I need that because of other programs compatibility reasons
Once you get it mounted with either method, the issue of x64 vs. x86 does not matter anymore, because it's a "virtual" file, and "looks" like a video. So you can load x86 avs scripts into 64bit programs like PP, AE , etc... -
ok no problem.
now when I go to pfm mount settings mapdrive 0 , local mount drive unticked , formatter auto
when trying to mount I get mount failure test clip.avs cant be mounted it is not of a supported file format
here is the avi clip info
Format : AVI
File size : 219 MiB
Duration : 3 min 0 s
Overall bit rate : 10.2 Mb/s
Writing application : Lavf53.24.2
Video
Format : MPEG-4 Visual
Codec ID : MP43
Codec ID/Info : Microsoft MPEG-4 v3 (pre-standard)
Codec ID/Hint : Microsoft
Bit rate : 10.2 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate : 20.000 FPS
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.328
Stream size : 219 MiB (100%)
the original clip was mp4 but I had to convert it to avi for it to work with virtualdub.
Is it possible to use this source clip mp4 in the avs script then mount as mp4 ready for premiere or is avi preferred? -
Original clip is always preferred .
I think you should be able to open it with ffms2 as a source filter , or perhaps lsmash . Both are external plugins
e.g.
LSmashVideoSource("video.mp4")
FFVideoSource("video.mp4")
Are you using x86 or x64 avisynth ?
What is the full script ?
vdubfiltermod (newer version, branch of vdub) should be able to open the mp4 directly too (but why were you converting it to avi to work in vdub in the first place?? )
Test that script is valid first, in vdub or avspmod , then mount it -
the mp4 file plays perfectly with vdubfiltermod is best to use the vdub64.exe? which I diid
Then what does opening the mp4 directly in vdub / vdubfm have to do with this ? You can open the mp4 directly in avisynth
BUT If I were you, I would encode an intermediate in that scenario. Because some of the filters in that script are not safe for non linear seeks. This makes editing very dicey when frame serving. You can get different results by jumping to different parts. You'll get mixed up results when making cuts and editing in a NLE. Some of the dirt removal for example - they only work correctly if you do it with a straight sequential linear access. -
I couldnt open mp4 in the older version of virtual dub
But you pointed out the version that did play the mp4 file i was just delighted that it did play black ok thats all
So what should i do now it my case its not stable send that script to premiere? -
So now would i just load the script in vdubfiltermod then save and process mp4 or avi format then just load the avi or mp4 in to premiere?
You would load the video with the script. You wouldn't be able to apply the script if you loaded the video directly into vdub/vdfm. You would edit the script to use lsmash or ffms2 as the source filter. (I think videofred's script has AVISource() )
The script applies all the filters and manipulations.
You encode the script to a physical file, an intermediate that you can import into premiere. This "bakes" all the results of the script into that video file, and eliminates the seek and consistency problems mentioned earlier because you encode linearly once, from start to end. For example, you can open the script with vdub (or anything that accepts avs scripts), then encode something to export out.
The problem is the intermediate can be large in terms of storage. A lossless intermediate can be many times larger than the original . A near lossless intermediate like cineform is quite common . The filesizes are not quite as large as true lossless, and the performance is very high in an editor (very smooth, fast seeking) . videofred uses hqx I think, which is also in the category of near lossless codecs. Cineform is quite a bit better in terms of performance, and compression ratio is similar.
The purpose of avfs is to "skip" that large physical file, to frameserve directly into another application. But in this case I strongly advise against it. Lots or potential for problems. -
I cant get the mp4 to with the script
Tried FFVideoSource("the path to the video.mp4")
vdubfiltermod doesnt recognise that command
How do i get freds script to work with mp4? -
It's not really meant to be "played" . You're supposed to encode to a video and play that. Since that video has all the results "baked" in, it will no longer be "slow", but realtime
It might "seem" slow, but it the grand scheme of things, this is not that slow . There are much slower scripts in the order of 50-100x slower.
Also you might be using the single threaded variant; I think there are multithreaded variations for that script which might a few times faster if you have capable hardware. But there are some hoops to jump through getting mt setup properly
In terms of "editing". This is also where the choice of intermediate makes a big difference in terms of editing performance. Some compression formats are heavily compressed and take a long time to decompress . Very sluggish on the editing timeline . Ideally you want a low latency, very fast codec for editing. Something like cineform will be 5-10x faster for seeking than a typical long GOP format if you have enough cores. You can "feel" the difference when scrubbing on the timeline . It's not a huge deal with SD, but when you're dealing with higher resolution scans HD or greater , it makes a big difference
How to resolve some errors with avs script?
By robusco in forum Video ConversionReplies: 12Last Post: 4th Dec 2015, 12:37 -
Cant get AVS Script to work
By bob52 in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2014, 12:27 -
I need a avs script to do something specific
By gil900 in forum EditingReplies: 2Last Post: 17th Nov 2013, 13:03 -
I keep getting these errors when I import my avs script
By beav in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2013, 22:55 -
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30
