I wanted to hit a target size for a video, and to give more room for the video data I kept the same codec, AAC, but reduced the bitrate from 48Khz to 44.1Khz. The resultant audio stream is bigger than the original. For a stereo stream around 45 meg at 48Khz the 44.1Khz output was around 57 meg while a 48Khz mono stream at just over 12 meg ballooned up to over 29 meg, and yes, I checked to make sure it's still mono.
With less data per second, other settings being the same, the output should be smaller than the original.
Of course the worst part of this is I'll need to start over from the beginning, either leaving the original audio untouched, or figuring out how to get the *expected result* of fewer audio bits per second actually producing less data.
I only twigged to this when I muxed one of the 44.1Khz mono streams into a video to replace the original stream and saw the new video file was bigger than before.
When you're seeing video files come out of the digital sausage machine at the requested size, and they look good enough, you don't think that the recipe is being altered in unexpected ways.
	Media info before
 Audio #1
 Format : AAC
 Format profile : LC
 Codec ID : A_AAC-2
 Duration : 48 min 12 s
 Channel(s) : 2 channels
 Sampling rate : 48.0 kHz
 Frame rate : 46.875 FPS (1024 SPF)
 Compression mode : Lossy
 Delay relative to video : -21 ms
 Title : Stereo
 Language : English
 Default : Yes
 Forced : No
 Statistics Tags Issue : mkvmerge v20.0.0 ('I Am The Sun') 64-bit 2018-02-27 00:30:36 / mkvmerge v20.0.0 ('I Am The Sun') 64-bit 2018-02-27 00:30:36 / UTC 2016-06-15T20:42:11Z
 FromStats_BitRate : 128139
 FromStats_Duration : 00:48:12.159000000
 FromStats_FrameCount : 135570
 FromStats_StreamSize : 46324796
 Media Info after. Note that Vidcoder doesn't include some of the data that was there originally.
 Audio
 Format : AAC
 Format profile : LC
 Codec ID : A_AAC-2
 Sampling rate : 44.1 kHz
 Frame rate : 43.066 FPS (1024 SPF)
 Delay relative to video : -23 ms
 Title : Stereo
 Language : English
 Default : Yes
 Forced : No
  transcode vob to mp4 - highter bitrate vs resize larger - how much of eachBy wolfdogg in forum Newbie / General discussionsReplies: 45Last Post: 25th Dec 2016, 10:41
  Help with reducing (either it's echo, or reverb from audio)By Infomaniac95 in forum AudioReplies: 3Last Post: 16th Nov 2016, 12:41
  Dolby Digital: effects of reducing bitrate.By ziggy1971 in forum AudioReplies: 9Last Post: 22nd Apr 2016, 03:11
  Direct Stream Video - But Keep Audio Codec & Change Bitrate in an MKV fileBy TheRandomOne in forum Video ConversionReplies: 1Last Post: 4th Jan 2016, 23:00
  Audio settings for VidcoderBy carlmart in forum AudioReplies: 4Last Post: 28th Aug 2013, 22:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
