Converted to dvd with convertxtodvd 4 and it is all stretched wide and narrow. Not sure did i accidentally change a convertx setting. When i play each individual vob with vlc it looks ok. But when i go media/open folder with vlc it is too long and not tall enoughGeneral
Complete name : C:\MOVIES\MY MOVIE.avi
Format : AVI
File size : 701 MiB
Duration : 42 min 58 s
Overall bit rate : 2 279 kb/s
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Bit rate : 1 821 kb/s
Width : 704 pixels
Height : 384 pixels
Display aspect ratio : 1.85:1
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.269
Stream size : 560 MiB (80%)
Writing library : XviD 1.0.0 (UTC 2004-05-09)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 2000
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Stream size : 138 MiB (20%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
ConvertX doesn't provide a log to show what you did or did not do? Based solely on your description, perhaps you added a total of 192 rows of pixels, maybe divided into 96 top and 96 bottom (576-384=192) to make it 720x576, which is not how it's done. Or, alternatively, use AvsToDVD to make your DVD.
Having trouble converting MKV to MP4
By greyhaven in forum Newbie / General discussionsReplies: 3Last Post: 25th Jul 2017, 09:58 -
Newb here. Having trouble converting VHS to DVD on Panasonic recorder
By CocoXO in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2016, 12:54 -
Having trouble converting and burning a DVD player video
By nite_hawk in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2014, 15:27 -
Trouble converting .flv to .mp4 and having it be useful
By Piefrenzy in forum Video ConversionReplies: 12Last Post: 7th Aug 2014, 19:48 -
Having Trouble Converting DVD
By jmg999 in forum Video ConversionReplies: 12Last Post: 27th Jan 2014, 10:12
