Hello,
i'm new in the video field and i'm doing a research, and i'm in need for a way on how to split a video into segments automatically and randomly where the segment duration can be defined. for example: i added a 3 minute video and the output can be 6 segments taken randomly each segment is 1 second.
if you can provide me with any tools or at least hint that it can be done either by some kind of codec or that it can only be developed by a software i would really appreciate it.
Thank you
There are many ways to accomplish your goal (if I understand it correctly).
I implemented a solution with AviSynth+ just to see if I could.
It's a little awkward without language support for arrays. VapourSynth might be a better tool here.
I assume you don't know AviSynth, so expect a learning curve. I added verbose comments if that helps.
Code:AviSource("your video here.avi") ## (implicit 'Last' variable = your master clip) ShowFrameNumber(x=16, y=16) ## for testing Trim(80, 0) ## optional - delete first X frames fc = Round(FrameRate) ## enough frames for aprox. 1 second ## create a bunch of 1-second clips ## (repeatedly take a 1 sec. clip off the front and remove it from master) ## clips must be named "A" through "Z" (26 clips max) A=Trim(0, length=fc) Trim(fc, 0) B=Trim(0, length=fc) Trim(fc, 0) C=Trim(0, length=fc) Trim(fc, 0) D=Trim(0, length=fc) Trim(fc, 0) E=Trim(0, length=fc) Trim(fc, 0) F=Trim(0, length=fc) Trim(fc, 0) ## for testing purposes - add visual ID A=A.bigsub("A") B=B.bigsub("B") C=C.bigsub("C") D=D.bigsub("D") E=E.bigsub("E") F=F.bigsub("F") ## this will become the final "edit decision list" edl = "" ## the initial list - one letter for every clip you want to output lst1="ABCDEF" len = StrLen(lst1) while (len>0) { ## pick a letter at random, remove it from 'lst1', add it to 'edl' i = Rand(max=StrLen(lst1), seed=true) ct = MidStr(lst1, i+1, 1) lt = (i==0) ? "" : LeftStr(lst1, i) rt = (i==(len-1)) ? "" : MidStr(lst1, i+2) lst1 = lt + rt len = StrLen(lst1) edl = (StrLen(edl)==0) \ ? ct \ : edl + "++" + ct } ## "execute" the edl string as a script fragment Eval(edl) ## for testing, show the edl Subtitle(edl, align=1) ## optional - save edl to file (re-use it with the Import statement) #WriteFileStart("<path>\random.avs", "edl") ## exit return Last ## for testing - show clip ID function bigsub(clip C, string msg) { return C.Subtitle(msg, align=2, size=C.Height, \ text_color=$aaffff00, halo_color=$ff000000) } -
Thank you very much for your feedback.. and i actually don't know AviSynth or VapourSynth but i don't mind learning them if they are going to help me with my research, but can i ask some questions regarding them; do they have libraries that i can use them in an application developed by Java or C# for example like the FFMPEG also, do they deal with audio signals? for example i want to do is that after randomly picking the segment video then separate the audio signal. and lastly as i noticed the code below:
i get the idea that the code is going to split my video into segments of 1 second then store them into variables; then a loop will randomly pick one of the letters to later display the video segment. is my understanding correct? -
Yes, many of the audio and video filters in ffmpeg also exist in AviSynth - and more besides. Here is a page describing them. There are many more filters available as plugins.
If you want to do advanced special effects or color correction, you would do better with a GUI interface - a real video editor. More on this below.
AviSynth is not primarily a procedural language like Java or C#; its basic function is to set up filter graphs, similar to ffmpeg's -filter_complex (described here) but much easier to work with in my opinion.
To start learning about AviSynth, you might want to scan the Wikipedia page:
https://en.wikipedia.org/wiki/AviSynth
Then install it and play with a few basic scripts:
http://avisynth.nl/index.php/First_script
VapourSynth has more procedural features (like arrays, as I said). You write VapourSynth code in Python, which you might like, I don't know.
Yes, it has support for basic audio mixing, editing and fading, but it's not suited to precision edits, or equalization, noise reduction etc - these things should be done in another program. Audacity is good for these tasks.
VapourSynth does not support audio.
> and lastly... i get the idea that the code is going to split my video into segments of 1 second then store them into variables; then a loop will randomly pick one of the letters to later display the video segment. is my understanding correct?
Yes, that is correct. It assembles a string containing all the clips in random order. Here's an example:This is a valid script fragment that is inserted into the main script with the Eval filter. The "++" symbols invoke the AlignedSplice filterCode:E++A++D++C++B++F
Having said all this, remember "there are many ways to do this." Another way would be to get a video editor that supports exporting and importing of edit decision lists (EDLs), cut your clips, export the EDL (which is a text file, one edit per line), randomize the clip order in some way (maybe in a spreadsheet) and re-import the EDL. This "hack" may not even be required. For all I know, there may be an editor with a built in "randomize" effect...
Easy splitting of long videos
By DJDJDJDJ in forum EditingReplies: 9Last Post: 4th Nov 2016, 00:41 -
Video splitting software
By stevenbyrd in forum Video ConversionReplies: 8Last Post: 28th Jul 2016, 16:45 -
how can code me a custom video edit software ? please need help.
By MS-HD in forum ProgrammingReplies: 0Last Post: 2nd Aug 2015, 07:06 -
WTD Software Discount Code
By Teac23 in forum Off topicReplies: 0Last Post: 19th Oct 2013, 05:59 -
need software from cutting/splitting/editing mkv files
By lalson639 in forum EditingReplies: 1Last Post: 2nd Apr 2013, 10:56
