  1. hi
    When you burn a movie or something on disk dvd
    Burning appears on this shape I have in the pictures
    There are incisions in the burn appearing on the disc
    [Attachment 44777 - Click to enlarge]
    My disk is burned This is my kind Graveur DVD lG - M-DISC
    How to solve this problem
    Those are zonal burning rings. You tried to burn it too fast. Or it's packet written.
    How, exactly, did you burn it?
    Oct 2005
    666th portal
    first does the disc work??? m-disc has a completely different structure than organic dye dvdr as it has no reflective layer and you can see through them. waste of money though, they were independently tested at the french national lab and last no longer than any normal dvdr.
  4. Originally Posted by lordsmurf View Post
    You burn at low speed 4x
  5. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Yeah, I thought M-DISCs were limited to 4x.
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Does the data have errors on your burned discs?
  7. Originally Posted by KarMa View Post
    Yes errors and disc stops working when running
    I would like to update it. Is there an update for this version?
    LG GH24NSC0
