Has anyone tried the new AMD RYZEN 3 2200G? How do its integrated graphics (RADEON VEGA 8) perform?
I just bought one, but haven't assembled the PC yet as the MB I got was defective.
When I get a replacement in a week, hopefully, I'll post a thread about the build.
It does come with a nice cooler with PWM leads. At ~ $100US, looks like a good deal.
But make sure you get a compatible MB.
I'd also recommend a M.2 boot drive, most of the compatible MBs come with that option.
https://www.amd.com/en/products/apu/amd-ryzen-3-2200g -
I think most current motherboards will need a bios upgrade to support it and will not work out of the box. Which motherboard did you choose?
I got the MSI b350m gaming pro mobo: https://www.newegg.com/Product/Product.aspx?Item=N82E16813144019 and the 2400g.
It booted using the onboard gpu with no problems, I just had to update to the newest bios to get it fully functional.
I've not done much testing, but it handles 1080p with Madvr NGU doubling, debanding, and rca with no problems. -
Tends to be slightly worse than a RX 550. And RAM speed is much more important with these APUs, than standard Ryzen, as it uses RAM for VRAM.
https://www.youtube.com/watch?v=tUT4zedxJhw -
I needed a fairly small MB for my PC case, so I chose a Asrock A320M-HDV
It's for a home office PC, so gaming performance is not an issue.
AMD Ryzen 7, Anyone using it?
By sum_guy in forum Video ConversionReplies: 6Last Post: 17th Dec 2017, 05:52 -
Ryzen encoding issues (Fraps and OBS both)
By Drunk Swede in forum Newbie / General discussionsReplies: 8Last Post: 17th Jun 2017, 00:32 -
Building AMD Ryzen workstation for video editing on budget?
By Hm... in forum Newbie / General discussionsReplies: 6Last Post: 21st Apr 2017, 20:49 -
AMD plans to release its first 3 Ryzen CPUs on March 2, 2017
By usually_quiet in forum ComputerReplies: 1Last Post: 2nd Mar 2017, 03:00 -
Some absurd AMD/Ryzen rumors to keep you tidy
By sophisticles in forum ComputerReplies: 0Last Post: 5th Feb 2017, 13:16
