I am looking for a script that will convert side by side (parallel) to the older field sequential format. Nowadays everyone wants to do the opposite which is understood and likewise there is a ton of info on how to do this. However sbs to fS script is not. Can anyone help me out?
The source was an overseas 3D blu I picked up (the Germans did a decent 2d to 3D conversion,but more pixel shift and rotoscope job for the 1982 animated film the Last Unicorn) that I then converted to sbs with BD3D2MK3D. The irony is that I love 3D but do not own a 3D set. I do have some 3D blues and player but if I truly want to view these I convert to sbs or anaglyph (I know) and view it on the pc in a small window (for side by side) so it doesn’t kill me eyes entirely (I can free view parallel).
I still have the older analog field sequential
equipment and would not mind viewing this film on my crt tv in that format
The 3D mkv made is also 16x9 which I would like to keep if possible
Results 1 to 9 of 9
I know I have copies of those scripts somewhere at home, so I'll look for them this weekend...
Scott Warren -
Off the top of my head, something along the lines of:
That's for two full width images side by side. For half width images change the resizing to width*2. I'm also not sure of the lower field image needs to be shifted down by a scan line. In that case, instead of resizing to half height use SeparateFields.SelectEven() and SeparateFields.SelectOdd instead of resizing the height.Code:WhateverSource("filename.ext") left=Crop(0,0,width/2,height).Spline36Resize(width,height/2) right=Crop(width/2,0,width/2,height).Spline36Resize(width,height/2) Interleave(left,right) AssumeFieldBased() AssumeTFF() Weave()
But you can convert to anaglyph without interlacing. Scripts for that have been posted many times here. For example:
https://forum.videohelp.com/threads/373046-HSBS-3D-to-Anaglyph-3D-Conversion-Avisynth-...bs#post2400867Last edited by jagabo; 23rd Feb 2018 at 17:25.
Thank you. Will be giving it a go over the weekend. I am also trying to avoid anaglyph. Though what I did find interesting with this film conversion is that the 3d appeared to look better under half color anaglyph than it did viewing it side by side (rare but occasionally that happens) when watching it on the fly (conversion) using Stereoscopic player
With sufficient PC you can do this in real time with ffmpeg.
https://trac.ffmpeg.org/wiki/Stereoscopic -
Thanks again but as mentioned in my first post the Stereoscopic movie player
https://www.videohelp.com/software/Stereoscopic-Player
can also do on the fly conversion quite well but I would rather be able to watch this edition on my dvd or bluray deck and for that I need to truly do an encoded conversion. And the script provided by Jagabo (and possibly also from Scott) will help me do what I need -
All above is true however Avisynth is inherently single thread (without MT) - ffmpeg offer some multi-thread capabilities, side to this conversion can be performed with ffmpeg and in semi-automated way (ffmpeg provide decoding, filtering and encoding within single binary thus you can avoid some problems with Avisynth).
I like Avisynth, i use Avisynth but sometimes it is not most optimal solution IMHO.
Need help with AVISynth script
By duffbeer in forum DVD RippingReplies: 13Last Post: 8th Sep 2016, 16:05 -
Best possible AviSynth Script
By Suwadith in forum Video ConversionReplies: 31Last Post: 10th Sep 2015, 06:43 -
Avisynth script help?
By PeterNL in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2014, 11:35 -
avisynth - How to write avisynth script for rgba overlay
By moelover in forum EditingReplies: 3Last Post: 13th Apr 2014, 12:24 -
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30
