"merge lines with same timecode" is great! But subtitle edit can convert only one file . Is there any way to batch convert subtitle files by this function ? Thank you very much.
Same question, I have many files that have lines that need to be merged, but I can't find a batch option. Is there a different way/software that has a batch mode?
Thanks. -
Yeah I use the batch convert option for other things, but the "merge lines with same timecode" isn't available in "batch convert".
All I could find in the "fix common errors" option was "fix overlapping display times", but it strangely doesn't fix all the lines, unlike the "merge lines" option. -
There is "merge lines with same timecode" in the batch convert,make sure you hae the newest subtitle edit.
[SOLVED] Adjust "timecode" rate to 24
By Rafael Linux User in forum Video Streaming DownloadingReplies: 8Last Post: 17th May 2017, 07:11 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
Is there a way to "stamp" a specific timecode into an avi file?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2013, 19:34 -
Weird "dancing lines" on edges of my video
By cfelicio in forum RestorationReplies: 9Last Post: 5th Aug 2013, 10:18 -
3D subtitles with Samsung UE46EH6030 - Subs do not "merge" at the center
By teks9 in forum SubtitleReplies: 0Last Post: 25th Jul 2013, 08:16
