Ok I was wondering if there was a difference capturing direct from a satellite box or capturing from the direct recorded PVR. Can someone easily say there is no difference?
The reason I'm asking is because the stream comes out of the satellite box to the TV uncompressed, so if record directly then I get the signal as it comes off the box. Now if I record off the PVR, the signal has to be recompressed to get to the PVR hard drive (doesn't it?) so by replaying that signal I'm wondering will I get the exact same quality? So at that point the signal has already gone through 2 compressions .. I think maybe there's no difference, but I don't know how the satellite box records the stream. Maybe there is some minor loss in quality, or the way it records maybe none at all?
	Oh wait I seemed to have already asked this question. It has been answered. Sorry for duplicating.
	Just for the sake of clarity... There will be no difference between a capture made from a live broadcast as it is decoded by a satellite receiver and a capture made from a recording the same broadcast stored on the satellite receiver. The recording made using the satellite receiver's DVR function contains audio and video which are identical to those in the original broadcast. Ignore list: hello_hello, tried, TechLord, Snoopy329
  Can anyone see a difference from these 3Mbps 7.5Mbps 9Mbps captures?By Christopher2222 in forum Capturing and VCRReplies: 9Last Post: 19th Feb 2018, 18:10
  Any differences capturing HD-PVR recorded or direct from reciever?By Christopher2222 in forum DVB / IPTVReplies: 6Last Post: 29th Jan 2018, 18:59
  Do i need to use --direct with Megui x264?By ben45 in forum Video ConversionReplies: 4Last Post: 12th Aug 2016, 11:49
  Best quality direct link?By CristianoA in forum Video Streaming DownloadingReplies: 3Last Post: 28th May 2015, 09:16
  Program that captures HDBy escarlate in forum Capturing and VCRReplies: 1Last Post: 25th Oct 2013, 09:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
