I want to make wmf files from avi or mpeg but I don't know what kind of software I need. What do you suggest?
tmpge will convert wmf to mpg make sure u have the proper codac, see tools on the left.
Nero wil also convert them as it burns the vcd. Get the free plugin from there website. Dont expect great output, but it will be watchable.
good luck -
I have TMPGenc and I can playback wmf files on my computer but I don't know how to choose the wmf output in tmpgenc!
Anyone knows how? -
To convert a mpg to wmf, If you have windows me just use windows movie maker inport the mpg then save the clip, it will be in wmf format.
Else go to the m/s website and get m/s media tools (there free). It will do the same thing plus much more.
good luck -
but if I want to use the wmv on my website do I need to install some additional server software
This is a freebie from MS:
http://www.microsoft.com/windows/windowsmedia/wm7/encoder.aspAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
