Hello everyone,
I use the newest version Mkvmerge v20.0.0 ('I Am The Sun') 64-bit to merge a mkv file, and then play the result mkv file on my BD player (via usb bar) but can not play forward or play chapter.
To resolve that matter, I add in the field "Default additional command-line options" (MKVToolNix GUI>Preferences>Merge>Default Values) the following line:
“--clusters-in-meta-seek --disable-track-statistics-tags --engage no_cue_duration --engage no_cue_relative_position”
I merge that mkv file again, error flagged:
--- Output of job 'Multiplexing to file "Test film (1).mkv" in directory "F:\USB\TAM1"' started on 2018-02-21 11:17:03 ---
mkvmerge v20.0.0 ('I Am The Sun') 64-bit
engage' could not be opened for reading: open file error.
Everyone know why, please help me?
(Note: I did successfully with mkvmerge older version 32bit, playing forward or choosing chapter fine with “Default additional command-line options” used as above)
You probably have some typo in your command. Like a missing quote or one too many in the wrong place. Or a space where it doesn't belong (between "--" and "engange"?) Or missing hyphens.
Without quotes, right?
I can't say more without seeing the complete command. But as you are using the GUI it is likely one of such fields with additional commands where you made an error. -
Thank you for your kindly reply, sneaker.
Exact command line (without quotes):
I used that line for my windows 7 32bit before and everything was ok. Now I upgrade to windows 7 64bit, with the same command line, that error occurs. -
After many attempts, finally I find that a missing in the command line: Before "--" of "--clusters-in-meta-seek..." should be a space, it should be:
Thanks to sneaker's clue above, I've solved my problem "engage' could not be opened for reading: open file error".
Thank you once again, sneaker!
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 03:24 -
mkvmerge won't open -- cmd screen comes up
By miba54 in forum EditingReplies: 4Last Post: 22nd Apr 2017, 17:19 -
Open MadVR in PotPlayer 32 bit
By loninappleton in forum Software PlayingReplies: 9Last Post: 9th Apr 2017, 23:19 -
Adding Logo with AviSynth (error 'Could not open file' in DevIL library)
By .craZy in forum EditingReplies: 12Last Post: 7th Feb 2015, 10:09 -
mkvmerge error
By Blackfoot in forum Video ConversionReplies: 2Last Post: 11th Sep 2013, 12:08
