Using DVDFab and Handbrake is it possible to create ONE MP4 file that has all English subtitles for BOTH English and foreign language scenes.
In particular, when I attempt to create an MP4 for The Hunt For Red October DVD the Russian dialogue does not show up on the screen in English subtitles, only the English speaking scenes. I have tried every possible option with Handbrake.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 15 of 15
Subscene has english subtitles for foreign parts The Hunt For Red October. You could use Subtitle Edit to make an OCR on your DVD and combine them.
Does the Subtitle Edit application allow you to open the MP4 file and add subtitles wherever you see fit?
Regarding Subscene, I've never understood that part of the subtitle process. I just always grab the subtitles off the DVD because it seems so much easier to do. It seems like there are SO MANY subtitles to choose from at the link you gave me. How would I know which one to use? -
No. SubtitleEdit can read subtitles from mp4 files and then e.g. combine and store them as .srt file. If you want to mux them back into mp4 you need to user a different tool (e.g. ffmpeg). But many players will auto-load .srt subtitle if they have the same file name as the video file (except file extension, of course) so often there is no need to mux at all.
If he wants subtitle for all parts anyways he might as well download the complete one and spare himself the trouble of combining and OCRing...
Try an English language release that has "DVD" in its name and is not "foreign parts only". Then test it. If it doesn't fit try a different one. Testing a subtitle shouldn't take more than a minute (click a bit around in the beginning, middle and end of the movie to see if it fits everywhere).
Let me take a step back here and try to explain my typical workflow and what I am experiencing with The Hunt For Red October.
Typically I use DVDFab to rip a DVD (Full Movie) and then use Handbrake to create two versions of a DVD: one without subtitles (for my wife and others) and one with subtitles (for me). I copy the resulting (subtitled) MP4 files onto my NAS and then play them from various Samsung Smart TVs in my house with no problem. For my wife I copy the MP4s (non-subtitled) onto a memory stick and plug them into the TV in the bedroom. 99.99% of the time this process works perfectly.
The problem is that for Red October I can't get the brief Russian dialogue to show up in either the non-subtitle version or the subtitle version using my existing workflow. All you hear is the Russian dialogue being spoken and that's it.
When I drag the VIDEO_TS folder into VLC player (on my PC) it shows me the DVD menu. Whether I select subtitles or not, during playback on my PC I am able to see the Russian dialogue as English subtitles so I know that they are there.
The question is why can't Handbrake produce MP4 files with English subtitles for the Russian dialogue scenes. I've tried the Foreign Audio Scan track option in Handbrake and that didn't work.
Basically what I need (using my existing workflow if possible) is the simplest way to produce two MP4s:
1) With NO subtitles whatsoever except for the Russian dialogue scenes (in English of course)
2) With English subtitles throughout including the Russian dialogue scenes
Can anyone tell me the simplest way to do this. There must be a way. -
It wont let you put bitmaps into an MP4, it's not supported, as per 'specs'.
I'm guessing there are two subtitletracks since
PS Or burn-in one track and softcode the other.
Help adding an extra set of subtitles to a foreign film
By Annebam89 in forum SubtitleReplies: 1Last Post: 4th Aug 2015, 23:14 -
where to get different Language Subtitles Matrix
By anime12345 in forum SubtitleReplies: 5Last Post: 13th Feb 2015, 01:31 -
Ripping subtitles from English BluRay when foreign speech is spoken
By bigkev1 in forum Blu-ray RippingReplies: 5Last Post: 1st Feb 2015, 11:51 -
Using Subtitles to Black Out Scenes
By Sades in forum SubtitleReplies: 8Last Post: 15th Jun 2014, 20:05 -
Subtitle Edit How to add Foreign Language
By 3TNT in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2013, 09:09
