Is there a way to properly remove Closed Captions from a DVD using Staxrip ? Simple subtiles are pretty easy but I haven't found any way rip CC.
Kelemvar
Staxrip doesn't provide the option to rip the closed captions from NTSC DVDs, as far as I can tell. The closed captions in N. American DVDs are stored in the MPEG-2 video's user data. When the video is re-encoded, normally none of the information stored in the user data is preserved.
If you want to extract the closed captions from the DVD to make subtitles from them, there are ways to do that for free. You first need to copy the VIDEO_TS folder from the decrypted DVD to your hard drive. Next, you need to convert the movie, extra features, or episodes in the copied DVD for which subtitles are desired into MPG files. I use the free version of VOB2MPG in IFO mode for that. The final step is to use CCExtractor GUI to convert the closed captions in the mpg file to SRT subtitles.Ignore list: hello_hello, tried, TechLord, Snoopy329
Closed Captions/ Subtitle coding
By rgreen in forum SubtitleReplies: 7Last Post: 6th Jul 2016, 16:00 -
Closed Captions
By cornemuse in forum SubtitleReplies: 2Last Post: 21st Sep 2014, 13:08 -
Can I get closed captions while streaming TV on my PC?
By amazin6 in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2014, 16:14 -
Remove Closed Captions?
By Mz Patti in forum SubtitleReplies: 6Last Post: 7th Sep 2013, 02:10 -
Capturing Videotape that has closed captions
By ian c-nall in forum Capturing and VCRReplies: 22Last Post: 4th Aug 2013, 23:33
