  1. Hello, Everybody! I'm new to the forums! My name is Andrew! I'm having a problem with 120fps footage recorded with a Sony FDR-AX40 to a SanDisk Extreme Pro 128GB SDXC UHS-I Card. I have attached the damaged frame and would really appreciate if someone could give me some insight. I just got the camera and I think the memory is probably the one to blame but I'm unsure. Thank you in advance!!
    Oct 2005
    666th portal
    i'd move everything off the sd card and then do a new low level format on it. any bad sectors will be removed from use. if it keeps happening try a different card and if that doesn't help it's a camera problem.
