I will need to upgrade to a new computer for editing 4K. I will buy Edius 9 (Link), although I'm not familiar with configuration of a computer.
At my work I have the opportunity to buy a Dell Precision Tower (5000 series), see link for possible configuration LINK. My budget is about 2500$. I would be happy to get some help
Regards,
Kes
8GB may be the minimum that Edius requires for 4K video editing, but you should plan on buying more RAM. A recent thread here indicated that 32 GB of RAM is not a waste of money for serious 4K editing using any advanced editing software.
If you hope to use GPU-based encoding, Edius requires the use of Intel Quick Sync. The Xeon processor in your configuration doesn't include Intel HD Graphics, which means that GPU-based encoding with Edius will not be possible. If you want the ability to do HEVC encoding with Quick Sync, a Kaby Lake or Coffee Lake Core i desktop processor is needed, but neither is compatible with the Dell's motherboard.Last edited by usually_quiet; 18th Feb 2018 at 15:52. Reason: clarity
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
GPU naming depends on whether you are buying a Kaby Lake processor or a Coffee Lake processor. For marketing purposes, Intel re-named "HD Graphics" as "UHD Graphics" starting with Coffee Lake, even though the GPUs are the same for both Kaby Lake and Coffee Lake processors. For example Coffee Lake's UHD Graphics 630 is the same GPU as Kaby Lake's HD Graphics 630.
2.1 speakers configuration under Windows 7
By kyrcy in forum ComputerReplies: 35Last Post: 15th Jan 2018, 04:07 -
Mpv configuration
By hisaishi in forum Software PlayingReplies: 4Last Post: 6th Jun 2017, 18:17 -
Help! Video Quality Configuration
By FamilyITGuy in forum Newbie / General discussionsReplies: 11Last Post: 17th Sep 2015, 11:05 -
please recommend Desktop configuration
By reddy963 in forum Newbie / General discussionsReplies: 14Last Post: 14th Jan 2015, 15:50 -
x264vfw configuration in VirtualDub- please help
By ofir_a in forum Video ConversionReplies: 10Last Post: 18th Mar 2014, 12:53
