Years ago, I downloaded an .mpg file of an episode from an old television show from the 1960's.
Sometime later I backed it up to an external USB drive. A couple years later, I backed it up again.
Recently, I was going over some my archives, and came across these two old backups. Of course, they are the exact same length. But, just out of curiosity, I wondered if they were byte-for-byte exactly the same. I mean, they should be-- they were both just copies of the same file (just performed several years apart). So, I used WinMerge to check, and, lo and behold, they were flagged as different. I then used the DOS utility "fc" (file compare-- with the /b switch for binary), and discovered that three bytes were different in the two files. The three bytes that were different differed in only 1 bit. The 4th bit (0x08) of the three bytes that differed was set in the second backup, and not set in the first backup.
Question: Is there a way to display the frame(s) in which the differences occur, just to see if they are observable (in the still frame)? "fc" does show the address of the each of the three bytes that are different, but I don't know how to use that information. The files are .mpg files that are 282,638,336. The results of 'fc /b' are:
01D05E7F: D4 DC
05361E7F: E1 E9
0DF20E7F: 51 59
A curious thing. I wonder why any difference at all. And, given that they aren't the same, why only 3 bits different in the whole file. If disk were damaged, wouldn't whole blocks get corrupted?
Anyway, I'm curious about how the differences might appear.
Thank you for any comments.
DG
P.S. Ever hear of "I'm Dickens, He's Fenster" (an old sitcom from 1962)? It's an episode from that series.
It's probably not worth the trouble, but you can get checksums for each frame of each video, and compare them:
https://trac.ffmpeg.org/wiki/framemd5%20Intro%20and%20HowTo
(yes, that was one of the first TV shows I ever saw, starring the future Gomez Addams, John Astin)Last edited by raffriff42; 18th Feb 2018 at 03:09.
Thank you, both, for helpful comments.
Maybe, some day when I'm really bored, I'll take the time to track down the offending frame(s)... just for grins. Thank you for the tip.
DG -
Heavily fragmented files will sometimes cause files (in my experience) to have errors when read. In the past I have simply defragmented the file or copyed the file off the drive to have it be error free. I'm not promising anything but it's worth defragmenting the file if it's on a HDD.
You can use HxD to find differences in files.
When transferring files I always use Teracopy as it has a file checker after a transfer to make sure the hash of the source and hash of the copy are the same. Windows does not check hashes of the newly created file when copying/moving files.Last edited by KarMa; 19th Feb 2018 at 00:35.
ffprobe can tell you the offset (pkt_pos) of each frame of the video. It gives you the information as a decimal value so you'll have to convert the hex value fc gives you. For example, the following in a batch file:
ffprobe.exe -v quiet -pretty -print_format json -show_entries "frame=coded_picture_number,pkt_pts_time,pict_type ,width,height,size,pkt_pos" -select_streams v:0 filename.mp4 > stats.json
will give you stats for filename.mp4 in json format as stats.json:
Code:{ "pkt_pts_time": "0:00:00.100000", "pkt_pos": "27687", "width": 1920, "height": 1080, "pict_type": "B", "coded_picture_number": 4 }, { "pkt_pts_time": "0:00:00.133000", "pkt_pos": "27372", "width": 1920, "height": 1080, "pict_type": "P", "coded_picture_number": 1 }, { "pkt_pts_time": "0:00:00.167000", "pkt_pos": "48476", "width": 1920, "height": 1080, "pict_type": "B", "coded_picture_number": 7 },
Mpeg2 video files duration 3hours burning on single dvd.
By nusratjaveid in forum Authoring (DVD)Replies: 3Last Post: 24th Jul 2016, 17:34 -
Merging two almost-identical frames in video
By Violinist1228 in forum Newbie / General discussionsReplies: 7Last Post: 1st Nov 2015, 07:16 -
Burning multiple video files into a single DVD disc problem
By Zwei in forum Video ConversionReplies: 2Last Post: 22nd Apr 2015, 07:50 -
AppHang opening .mov files with AVIDemux 32 bit but not 64 bit.
By redwudz in forum EditingReplies: 9Last Post: 4th Mar 2014, 20:47 -
How to convert multiple xvid files into single video file
By alex2356 in forum Video ConversionReplies: 21Last Post: 22nd Oct 2013, 16:14
