I want to burn a video to a dvd-r disc for a friend that I trade classic tv show episodes with.
I have a new computer with windows ten and even with a dvd-r blank disc windows ten still insists on making it dvd-rw
My friend doesn't want a dvd-rw disc he wants dvd-r's for his collection. What do I do?
Results 1 to 9 of 9
DVD-RW are rewritable. You can write to them, erase it, write again, many times.
DVD-R can only be written to once. You can't magically turn a DVD-R into a DVD-RW, no matter what Windows says (or, possibly, how you're misinterpreting what Windows says).
The differences are explained here.
Just do as davexnet suggests and use ImgBurn for the job. -
nancyann, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
Manono,
I don't want to change a dvd-rw to a dvd-r disc. I want to burn a video file to dvd-r but windows 10 will only do dvd-rw. -
It sounds like you are trying to use Win10's packet-writing (aka disc as a removeable hard drive) capable utility.
You do NOT want't to do that.
First, it is wasteful of bytes (overhead for packet transition sectors).
Second, that is not the type of disc format that DVD players expect (udf 2.50+ vs. Dvd-video's micro udf 1.02/bridge).
Third, as you have found out, it only works fully & properly when you use RW discs.
Again, use a proper Disc-at-Once burning app, such as ImgBurn. It also recognizes proper dvd-video folder structure, so it puts it in the proper sector order on disc, and makes it udf1.02-compliant.
Also, I note you said "video file". But a proper dvd is a structured arrangement of certain files in a certain folder, with certain properties. Not just some "video file". It needs to be authored (and compiled) first.
DVD Styler - How to quickly burn multiple copies of the same disc?
By Gameshow Host in forum Authoring (DVD)Replies: 4Last Post: 1st Jan 2016, 09:40 -
video blu-ray burn to double layer DVD disc
By toomail in forum Video ConversionReplies: 11Last Post: 9th Jun 2014, 20:29 -
Backing up DVD from disc to computer & Burn to disc
By callidus in forum DVD RippingReplies: 9Last Post: 17th Mar 2014, 11:49 -
long time to burn and extract dvd data disc
By gamemaniaco in forum DVD & Blu-ray WritersReplies: 10Last Post: 2nd Sep 2013, 09:32 -
Best software to burn 720p hd video to a DVD disc
By rad0909 in forum Authoring (Blu-ray)Replies: 4Last Post: 19th Jun 2013, 03:27
